Another will I hit 10's thread..... I am an autocross guy and new to straight track so here we go..... 94 Camaro Z28....Brand new stock shortblock (LT1), A4, milled LE heads, 227 Crane cam, 1.6rr, larger injectors (I think 30's), 3000 stall, 3.23 gears, 150 shot dry, LT headers, ORY, cut out, no cat, 16" drags with some weight reduction. Guessing Hp 360 to the ground (motor only) 510 with the juice (rwhp). Will I make it? |
what kind of suspension is under the car? should be close on the spray but you will have to 60' pretty good. try it is all you can do. |
Originally Posted by 021less
(Post 11748706)
Originally Posted by fuzzyjk
(Post 11747899)
| All times are GMT -5. The time now is 07:26 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
