LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   10 Second Club (https://ls1tech.com/forums/10-second-club-88/)
-   -   10's NA (https://ls1tech.com/forums/10-second-club/1827598-10s-na.html)
SRB02SS Apr 8, 2016 09:20 AM
10's NA
Finally took my Tick Performance built full weight camaro to the track. Car went 10.78@125 in the 1/4 and 6.87@99 in the 1/8. Car probably weights 3750-3850 with me in it. Guess its time to start pulling weight out of it and start on suspension and rearend.
Jtm2085 Apr 8, 2016 02:35 PM
Good runs. Details on the build?
SRB02SS Apr 8, 2016 03:47 PM
All details are in my signature.
Jtm2085 Apr 8, 2016 05:02 PM
Ten four, I sill have to get on a computer to see it
SRB02SS Apr 8, 2016 06:03 PM
Tick Performance built 408 with cnc LS3 heads with 11.5-11.7 compression, BTR valvesprings, custom grind Cam Motion cam by Martin Smallwood of Smallwood Race Developments. Ported ls3 intake from BER. Kooks 1 7/8 race headers to TSP true duals. Yank SS4000 stall converter. Rebuilt 4l60e and factory 3.23 rearend for now.
senicalj4579 Apr 8, 2016 06:16 PM
What was 60' and DA?
The car should respond well to some weight out.
SRB02SS Apr 8, 2016 06:28 PM
1.50 60' and I'm not sure what the da was... It was in the 50's as far as temperature but there was a good bit of moisture in the air and elevation is probably 75-100 feet above sea level.
senicalj4579 Apr 8, 2016 06:38 PM
Damn good 60' especially for that weight. Any plans for weight reduction? Did you notice any added weight from the iron block?
SRB02SS Apr 8, 2016 07:03 PM
I can't feel a difference with the iron block. Feels the same to me. Wish i had 3.73 gears and a 12 bolt rear.
Martin Smallwood Apr 10, 2016 05:57 PM
Great job Scott!
If you can get the weight around 3500lbs with you in it, she should be a consistent low to mid 10 second ride!
SRB02SS Apr 10, 2016 06:12 PM
Thanks Martin. Couldn't have done it without you. Yeah I got a friend already planning on helping me pull some weight out of it in the future.
© 2026 MH Sub I, LLC dba Internet Brands
