A little n20 and th400 swap
After dealing with the typical issues of racing a 6speed car for a couple seasons I decided it was time to swap in a th400. The car ran consistent 11.3x's at 124 with 1.6x 60ft times using the m6. I replaced the t56 with a FTI th400 and one of their custom converters. I had installed a used nitrous outlet plate kit right before I pulled the t56 but never made a pass on the spray.
-ls6 crate motor with hand ported heads, BTR 4 cam and FAST 102
-3540lb raceweight
-4.11's and 26in stiff wall slick
-150 shot
The first pass I let out at the 1/8 and made a personal best (left slip, right lane). I went on to run the full 1/4, spun on the hit then ran out of gear and had to let out multiple times due to being all over the limiter. Over all I am very happy with the new set up. The converter seems to be quite lazy on motor how ever. The DA was 20xx for these runs
-3540lb raceweight
-150 shot
