LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   10 Second Club (https://ls1tech.com/forums/10-second-club-88/)
-   -   Is this 3200 vig & 3.73's enough? (https://ls1tech.com/forums/10-second-club/402324-3200-vig-3-73s-enough.html)
nat Oct 30, 2005 12:25 PM
I will be building a 427 with 225 AFR Heads, Fast 90/90, custom 236/240 114 cam and all the usual bolt-ons. Will this 3200 vig. & 3.73 gear be enough to get me low 11's or high 10's @ 3600 lbs?If so, what kind of MPH does a4's run in the 1/4? I know that the cam is small, but I am looking for great drivability and performance all in one package. Give me some of you expertise for my goal. Thanks :chug:
BrianC98Z28 Oct 30, 2005 02:03 PM
you should be able to pull atleast 1.5 60ft if not better. I pulled 1.65 on stock suspension in my bolton car.
69_YENKO Nov 20, 2005 08:49 PM
I ran a 10.85@127.96 with a 3,200vig and stock 3.23s. so far on a 26" tire all i have pulled is low 1.6s
texada Nov 21, 2005 04:35 PM
What set up do you have?
© 2026 MH Sub I, LLC dba Internet Brands
