Question for those of you running 10's Im hoping within the next couple of months to be here along with you guys, just wondering if Im taking the right direction. I am running a forged 346 9.5 to 1 compression ls6 intake, 60lbs injectors, tr224 114 cam (I know that this is probably not the best cam but I live in CA and need to pass smog), AFR 205 heads, and flp headers. I will be running between 10-12 #'s with a D1SCand 8 rib setup. I have all supporting mods rear, fuel ect. I also have koni da's with hotchkis springs and BFG drag radials. Do you guys think this will be enough to get there or will I need more boost? Thanks |
I think you should hit it! |
| All times are GMT -5. The time now is 12:08 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
