LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   10 Second Club (https://ls1tech.com/forums/10-second-club-88/)
-   -   looking for 10's (https://ls1tech.com/forums/10-second-club/452277-looking-10s.html)
mightybird Feb 11, 2006 02:03 PM
looking for 10's
tsp magic stick /patriot stage 2 heads 2.05 valve heads/ ls6 intake /3600-3800 stall/ race tronics fuel pump/and a 200 shot /stock short block/i dont want to do the short block just yet but i would like to beable to run low 11's to a high ten.
SPRAYED T/A Feb 11, 2006 03:14 PM
That should be no problem.I ran 11.5 with stock internals just full exhaust on a bfg
drag radial and a 150 shot. The only thing i would think about with a 200 shot are the
main and connecting rod bolts. Ive heard they can stretch revving high and pushing
all that power. Apr sells the high performance bolts. Good luck!!
mightybird Feb 11, 2006 05:31 PM
i was thinking of a 150 shot today would u think i would need a gear change least a 3.73 or 4.10 gears with that 3600-3800 stall
SPRAYED T/A Feb 11, 2006 08:14 PM
I would got with the 3.73 for sure with big of a stall. Do you have a stock rear end?
mightybird Feb 12, 2006 10:15 AM
ya stock rear with a gurdle and some hardend lug studs. i dont have the tires to kill it yet. i figure its time for a 12 bolt or 9 inch when i get some slicks
LookinAtMyPlate Feb 12, 2006 07:46 PM
if you can drive you can hit high 10's with a 200 shot.
your rear end might see its last run though
© 2026 MH Sub I, LLC dba Internet Brands
