Pushing for 10's Well i hope im not in over my head but i have stock weight on my car full bolts ons,car goes to MTI for Stage 2 E port and polished heads, comp cams 231/237 .598/.608 on a 112 with a underdrive pulley, and 3.73 gears with a 3200 stall(all dyno tuned). Im also adding nittos for the strip, are the 10's possible?? :confused: |
No, mid to low 11's. Just not enough power with ur stock weight. |
You might want to try a better tire than Nitto. M/T drag radials, and BFG drag radials are superior than Nittos. If you are not running nitrous I would recomend steeper gears and if you are going to try and ru tens, consider a stronger rear end. Stock rear ends arn't to strong. One real good hook and boom. A higher stall would be a good option. Getting out of the hole makes a big difference. I hope this helps. |
What head gasket and what size head chambers? If the quench is tight and compression around 11.5 you will be close but you might need to lose a little weight. Bob |
| All times are GMT -5. The time now is 11:16 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
