LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   10 Second Club (https://ls1tech.com/forums/10-second-club-88/)
-   -   is this enough for 10's? (https://ls1tech.com/forums/10-second-club/696923-enough-10s.html)
white00z Apr 15, 2007 08:56 PM
forged 347 with 100 shot of nitrous, magic stick 4, PRC stage II cylinder heads, LS6 intake, L/T's, and other bolt ons. And about how much power you think i would make to the wheels? is basically that TSP 347 long block.
white00z Apr 15, 2007 09:00 PM
i would eventually get a better rear end, some tranny work, slicks and a little suspension work, but all im trying to see if that setup would make enough power for 10's.
TeEnAgE pHeNoM Apr 16, 2007 08:42 AM
It should run 10's but you are more than likely going to need a 9" or 12-bolt rear end, some suspension, and some sticky tires.
It really depends on if the car is a 6-speed or an auto?
98Z28MASS Apr 16, 2007 01:20 PM
Power wise it shouldnt be a problem, but again as everyone else said it is gonna come down to if you can hook up or not at the track and if you do will your stock tranny/rear hold the power or grenade.
Ericbigmac83 Apr 16, 2007 01:30 PM
yup, its got the power, you'll see 10's if you have the traction, and prolly close even without traction
white00z Apr 16, 2007 08:18 PM
i have an auto, and yeah i would eventually get a 12 bolt and some slicks, tranny wise for now just a converter, how long you think that tranny would last?
TeEnAgE pHeNoM Apr 17, 2007 08:25 AM
It might last one pass or it might last 200 passes. You never know with those trannies. Just don't spray it through the shifts and it should hold up a little longer. The rear end also is fine for an auto car there are plenty of people running in the 10's with a stock 10-bolt.
© 2026 MH Sub I, LLC dba Internet Brands
