Is this capable of 10's.. Do you think that this is a consistant low 11's Car, or is it in the 10's.. I always had the LT1 in the Car, never really drove a Stalled LS1 Car. Specs: 6.6l 402ci IRONBLOCK STROKER EAGLE FORGED 4" CRANK/6.125" RODS/MAHLE 4.000" PISTONS, FULLY BALANCED GM L76 INTAKE/GM L92 HEADS MILLED TO 65cc CHAMBERS, 10.8:1 COMP. LS2 FUEL INJECTION/HOLLEY 90mm THROTTLE BODY/85mm Z06 MAF COMP CAMS CUSTOM GRIND: 243/247, .621(XFI)/.612(X-ER), 114+3 LSA FULL TUNE, SHIFTING AT 6500RPMS PACESETTER RACING LT's, 3" ORY INTO A 4" BULLET, DUMPED YANK SS3600 STALL/FULL BUILT 4L60E WITH 3.73's, 26" M/T ET STREETS UMI PERFORMANCE TUBULAR REAR LCA'S & PANHARD BAR, POLY BUSHINGS UMI PERFORMANCE 3-LINK TORQUE ARM WITH TUNNEL BRACE MOUNT & DRIVE SHAFT LOOP CAR WILL WEIGH APPX. 3350 AFTER EVERYTHING IS IN, INCLUDING ROLL CAGE & SUB FRAME CONNECTORS What do you guys think? |
Damn.. not everyone at once.. |
I'd say def. low 11's with some good shoes on there...would be sweet to see it get in the 10's...what kind of rear end is on there? |
Right now it's a Auburn Pro Series 10-bolt with fresh Motive 3.73's, I plan on eventually a Moser 9" with 3.73's, maybe 3.90's if I need it. That Stall isn't too bad.. |
| All times are GMT -5. The time now is 11:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
