LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   10 Second Club (https://ls1tech.com/forums/10-second-club-88/)
-   -   is this enough for 10's? (https://ls1tech.com/forums/10-second-club/728751-enough-10s.html)
white00z Jun 8, 2007 11:30 PM
forged 347 with 11.1 CR, MS4, PRC stage 2 Ls6 heads, Fast 90/90, 3800 stall, Long Tubes and the rest of boltons. This would be with ET streets and my rearend would probabbly break but all im trying to see if this set up would make enough power.
NoGamesLS1 Jun 8, 2007 11:33 PM
m6/a4? stall/clutch?
white00z Jun 9, 2007 05:39 PM
A4 with 3800 stall.
Evans752 Jun 9, 2007 05:40 PM
It should be in my opinion. Nedde a gear and a set of tires and a good tune. Good Luck
NoGamesLS1 Jun 10, 2007 04:13 AM
Only one way to find out :) You should be low-mid 11's at least.
white00z Jun 10, 2007 11:02 AM
i would be happy with mid to low 11's and than just spray it in to the 10's
Smokinstorm Jun 10, 2007 12:06 PM
You should have enough power to do it. It's just a matter of whether you can use all of what you have available. My power curve shouldn't look too terribly different from yours and my car ran a high 10. If you have to roll slowly into the throttle out of the hole to protect your rear end however, it's not going to happen.
white00z Jun 11, 2007 06:43 PM
so this rear ends can probabbly take a little bit of abuse?? because a lot of people say they are junk and they break real easy.
02SOMWS6 Jun 11, 2007 07:47 PM
Don't get it twisted, the stock is junk. However it will last a little longer with a auto. You could try and get a set of moser axels and a spool for the 10 bolt to try and make it last a little longer
© 2026 MH Sub I, LLC dba Internet Brands
