Ran Low 11's Mods: PP LS6 STG 2 heads, Fast 90/90, TR224/227 570ish 114, EWP, Stainless works 1 3/4 headers, magnaflow catback, TR6 plugs, Yank SS3600, Mickey Thompson Drag radials 275/40 /17 and 100 shot N20 dry, 100 octane, 10bolt, 3:73's, full weight, 80,000 miles on the bottom end First pass N/A 60' 1.671 330' 4.862 1/8 7.531 MPH 91.79 1000' 9.838 1/4 11.775 MPH 116.82 2nd pass 100 shot Dry Spraying in 2nd gear 60' 1.679 330' 4.757 1/8 7.285 MPH 97.75 1000' 9.444 1/4 11.263 MPH 123.94 Next day OCT 19 Made one N/A pass 11.746 @ 116.60. Then a N20 run Spraying just out of the Hole. But had 2 issues during the run. 1st was hitting the limiter going into 2nd and getting off the throttle and back in it. Then at the 1000' mark the Air fitting on the passenger header broke off so I coasted thur the traps thinking the motor went. :bang: Could have been a 10 but oh well :D 60' 1.632 330' 4.644 1/8 7.215 MPH 96.24 1000' 9.401 1/4 11.255 MPH 118.35 |
Time to work on that 60'. Some solid 1.5s and it would be alot faster. |
Originally Posted by JonCR96Z
(Post 10380504)
Time to work on that 60'. Some solid 1.5s and it would be alot faster. The suspension could definatley be better reguardless of track prep. What kind of 60' and 1/4 times are you getting with your setup? |
Easy 10s. (The 60ft time on the nitrous pass in my signature was 1.59) |
| All times are GMT -5. The time now is 04:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
