I hope I can make 11s
i have a 2000 t/a with the following
ported 243 heads w/5 angle valve job
4.10 gears
mahle forged pistons
hellfire rings
ported ls6 intake
lca's
panhard bar
slp long tubes, no cats, and cutouts
comp t/a kdw2 tires
comp cam lifters
comp cams custom ground 234,236 110+4 lsa camshaft
tuned to 425hp and 399tq on a mustang dyno
also have a vortech v9 kit on the way that I will be running at 9psi
do you think 11s are possible?
4.10 gears
hellfire rings
ported ls6 intake
lca's
panhard bar
comp t/a kdw2 tires
comp cam lifters
Uhhhh.....I would really hope so. If not I would be very disapointed as the owner. Take a look at what mods are used to reach 11's. I would assume your a 10 second car on paper. Getting the power to the grownd will be the task. Good luck
I write checks with my mouth that my ass can't cash
lol all that **** and your hopeing for 11s ? im gonna break 11s on a stock stall, stock internal car ! i would be shooting for easy if u can hook up... also assuming ur car isint 4000 lbs.
