First time out on new build 11.22 @119
first pass off the trailer on my new build. Still need to setup the suspension and tune the carb.
Setup is a 383 ls1, Forged RA, AI ported/milled 243s, AI custom grind, Super victor, Mark Sullens E85 carb, Kooks 1 7/8s LTs, TH400 RMVB, tbrake, Moser 9", Et street pros.
I need to get it dialed in on motor then im spraying a 250 on the fogger and 100 on the plate. I need to sort out a few issues then im going back for a 10. My trans wasn't wanting to shift so it hit off the limiter a few times.
Also im sending my converter off for a reflash since this one was off a turbo car.
Im only good for 11.50s because I have a 6pt and I have ttops. I need an 8pt to go faster.
Im not sure what you mean by that? but my rpm wasn't consistent as I was having trans issues. You can hear on the top end that the rpms would raise and lower. I had get out of it in order to get it to shift, then get back in it. my 2nd pass It went 14.27 @ 121. I got on the trans brake and it didn't hold so it jumped forward and I redlighted. so I got on the brake and made the pass. my 1/8th mph was the exact same but my trans shifted better. my last pass, the idiot set me up on a pro tree without telling me, so I was waiting for separate ambers. I had a .594 rt, 1.65 60', 98 mph 1/8th and ran 11.40 @115. that pass my 3rd gear didn't engage at all.
what he meant above was that the mph gain from 1/8 mile trap to 1/4 mile trap was much lower than you would expect on a car of that power level , you only gained 21mph on the last half of the pass that would be pretty normal for a 13 second car not for a low 11 sec car. Either there is a power loss happening in the top half or a gearing/tire height mismatch where your not currently crossing the traps at the optimum rpm for your setup. Rectify that issue and you will likely crack 10's before spray
oh damn. my 2nd pass I went 121 mph.
I'm thinking that trans needs a rebuild if it's having shifting issues.....should be clean and firm to hold the power.
Also if you plan on spraying that much **** through the motor, you will need a REALLY tight *** converter. One that literally bogs the thing on motor in order to be able to handle the 300 foot pounds of torque spike when hosing it.......
