Ran a 7.414 in the 1/8. Hope to take it to a 1/4 track soon 1 Attachment(s) |
Details on the car? I would say that's a good 11.7 or so |
1998 A4. It was a Virgin stock when I got it. I put a Texas speed 228R112 cam. 3200 stall long tubes. Trans cooler. And a 125 wet kit. Changed out the 323 gears for 373. And that was it for that pass. (On DOT slicks). It had stopped error lead stop fuel pump and a copycat tune. I have HP Tuners. And a wide band on it now data -logging A Walbor 340 pump and some suspension parts. Can't wait to take it to the 1/4 track |
You're pulling a decent 1/8 with a poop 60' like me. That's good mph. Your car should backhalf more in the 11.6 range unless something in the setup shits the bed |
I personally thank it could pull a mid 11 second pass. I ran 7.20 and 7.19 with a 1.5 60 foot at 94 mph the ran 11.3 in 1/4 on both of those passes at 117. https://cimg3.ibsrv.net/gimg/ls1tech...eac1eb7df1.jpg |
Yea I agree. I will find out soon. But I got a lot of suspension parts I am putting on right now so I hope to go even lower. I got 90/10 struts subframe connectors lower control arms relocation brackets tubular torque arm and Pen hard bar |
Any plans for a looser converter? If you can get that sixty down the car should pick up a lot. |
I think the suspension will help my 60. With that first pass I didn't even have subframe connectors I think my 60 should be in the 1.5s next trip. It is still my daily driver. I have a yank SS3200 |
The suspension should no doubt help. Keep us updated with the results. |
If it wasn't spinning the suspension isn't going to help imo. Needs a bigger converter to get that 60 down. When were you activating the nitrous? |
1 Attachment(s) Thanks Aaron I will. 👍 Mad Mike. I use to run try-street in a mustang and built street/strip cars for others. My suspension kit for them would take a 13 sec car (on slicks not spinning) with a 1.75 60 foot. (3300lb car) make it run a 12 sec pas with a mid 1.4 60 Attachment 550682 That car ran 10.80s on motor and 9.60s on a 175 wet kit. 347 10 and 1/2 to 1 comp |
Originally Posted by liketowork
(Post 19389781)
Thanks but I can't take the credit it was a set up that a super Street outlaw guy told me about Thanks to Lance Stick of custom performance Americus Georgia |
If anybody has a fox body and wants to hear what all is in that suspension set up our list it for you |
I agreed if it wasn't spinning before the suspension will be but not going to be huge. I'm still running stock suspension with front sway bar removed and a adjustable panhard bar from MWC. Other than that it's got stock lca's, no subframe connectors, and everything else is stock. I still need to throw that stuff on. I also run an FTI 4400 Hard Hit converter and daily drive the car, it's like it's not even there until I lay into it. Haha |
Yes the suspension does 2 main things. 1. Transfers the weight/power. It does this by the struts being 90/10. The struts don't hold against the front end coming up and the rear springs (changed to less of a load rate) let it come down the engine mount and trans mount. (Solid or poly) eliminate flex (flex takes time from your ET). Subframe connectors keep the body from flexing ( subframe connectors are usually good for 2-tenths in the 1/4) Torque arm that don't flex. Lower arms that don't flex pan hard that don't flex 2. The car won't unload going down the track so you are not pushing the nose weight. ( relocation brackets and 90/10 struts aid in this). So does setting the pinyon angle Al the weight stays on the back tires. 4400. Cool. Sound like you have a nice set up. You will love your suspension. |
I know what suspension does but what we are getting at is if the car is already hooking well then it's not going to help much. And I cut 1.50 60 foot all day on the stock suspension with the 4400... |
For example subframe connectors don't help you hook it takes movement out of the body and gives you 2-tenths in the 1/4 that's just 1 part slicks make you hook if your slicks are not hooking you need to play with the air pressure or get the right slicks suspension is the geometry that puts the power at the crank to the wheel on the track |
There's no way you're going to hit 1.5 60's just from adding subframe connectors. At your power level, you'd be lucky to see any improvement unless you start stripping weight off the car. And even then, your 3200 stall is only going to get you so far. After having a ST3500(2.7 STR) for 12 years, I'm finally moving to a 4000 because I want better 60's. I've got subframes and all CM suspension and my best 60 ever was a 1.59 @ 3520# Raceweight. Went to a SS4000 and hoping for low 1.5 60's @ 3470# RW. |
I said subframe connectors are good for 2/10 in the 1/4 as in ET. I did not say in the 60 foot but I did cut 1.39 60 foot in my last race car (on motor) but it was a Mustang |
© 2024 MH Sub I, LLC dba Internet Brands
