11 Second Club Snake eyes are a good thing
Finally hit snake eyes! 11.87 @ 122.8 - Update - 11.18 @ 123.2!!
Old 04-24-2017, 12:22 AM
manzo81maro's Avatar
Thumbs up Finally hit snake eyes! 11.87 @ 122.8 - Update - 11.18 @ 123.2!!
Hey guys,
Went to TMP today and ran a new best of 11.87 @ 122.8 mph on a 2.01 60' @ +800' DA
https://www.youtube.com/watch?v=3j1Q...ature=youtu.be
not only did I break into 11's, but I also finally broke the stock 10-bolt a couple passes later (it's taken a beating)
Time to throw in my S60, a real tire, and dig deeper into the 11's
Old 04-24-2017, 06:09 AM
FrankieD's Avatar
Congrats. Soon you will be chasing for 10's.
Did you have to get towed home?
Old 04-24-2017, 07:16 AM
murphinator's Avatar
trap says its got low 11's in it , surprised you broke the 10 bolt with a 2.0 60 foot , usually they break when they hook up not spin...
Old 04-24-2017, 08:10 AM
Yea got a tow, but I have CAA so no charge
Old 04-24-2017, 08:12 AM
It broke on the 1-2 shift
Old 04-24-2017, 08:13 AM
Rise of the Phoenix's Avatar
Congrats! I'm hoping to be in the low 11's as well. Just put the FAST 92/92 setup on which should put me at 470rwhp. I hope my 10 bolt has better luck than yours.
Old 04-24-2017, 09:28 AM
WidowrRacing's Avatar
Congrats man!!
That's def a low 11 already with that MPH.
I did the Moser 12 bolt swap when I bought mine last year.
Old 04-25-2017, 11:01 AM
Thanks guys! Low 11's is the goal with a good launch...10's with a plate kit
Old 04-25-2017, 12:00 PM
LaBLKv6Z's Avatar
Congrats, I'm hoping to do the same this weekend. Minus popping the rearend, (s60 already installed).
Old 04-28-2017, 07:49 AM
Firebirdmuscle's Avatar
Yeah mph has capability for high 10's very low 11's. Keep at it op. You'll enjoy the new mods
Old 06-27-2017, 06:27 PM
Mike Morris's Avatar
I think you can go 10s the way you are. Just need traction
Old 06-27-2017, 08:54 PM
HCI2000SS's Avatar
Very impressive mph for sure! What is your raceweight, and what tire and wheel setup do you have?
Old 09-22-2017, 08:02 AM
Well, I finally got her back up and running with a good tire, drivetrain & suspension setup (see sig)
Raceweight not confirmed, but I'm guessing ~3700lbs
Gained weight in the drivetrain but dropped 60lbs in wheels/tires and deleted A/C
Got some seat time, and with minimal suspension tuning, here's what she managed
Attachment 718931
Still some work to do on suspension to get the short time down some...also planning a K-member swap to drop some weight off the front, however BIG improvement since April run...really happy with how the car is working so far
Let's see if we can get that 10.99999 before year-end
Old 09-22-2017, 08:10 AM
HCI2000SS's Avatar
Nice job. Looks like that heavy S60 didn't slow you down any
Old 09-22-2017, 08:15 AM
Tuskyz28's Avatar
What heads and cam doing the magic?
Old 09-22-2017, 08:24 AM
HioSSilver's Avatar
Nice job...what gear/tire size you running? Rpm?
Old 09-22-2017, 10:09 AM
It makes the 10-bolt look like a tooth pick...but I think the weight I took out of the car (ie. lighter wheels, !A/C, lighter clutch) offsets most of the weight gain in the drivetrain...T56 Magnum I think is also about 20lbs heavier than the stock T56
Mamo worked AFR 215 cathedral heads @ 60cc ~11.5:1
Mamo spec'd 227/231 cam
Mamo ported and shaved FAST 102 & NW 102 TB
Thanks man,
S-Trac with 4.10 gears and 27 x 11.5 Hoosier QTP
I think it's trapping around 6200rpm...
26" tire or 4.30-4.56 gears would work better but I built it to leave room for spray and extra sidewall on the 27" tire is nice
Old 09-22-2017, 10:25 AM
Tuskyz28's Avatar
Smallish cam and BIG mph=
Old 09-22-2017, 10:48 AM
cam
cam's Avatar
Congrats!
Old 09-22-2017, 12:54 PM
Yes sir! Best trap was 123.95mph...I did switch from a standard SSRA to a mega mouth SSRA with my A/C delete (busted the standard one pulling off the road), so that was probably worth a little
I think she'll hit 125 and maybe that magic 10.9999 in better air
Quick Reply: Finally hit snake eyes! 11.87 @ 122.8 - Update - 11.18 @ 123.2!!
