11 Second Club Snake eyes are a good thing
Ls1 irocz first Track run: Updated
Old 06-12-2017, 09:22 AM
wph351's Avatar
Default Ls1 irocz first Track run: Updated
After a year long build finally took my 1987 iroc to the track. It's a full weight car with the following mods.
2000 5.7 sbe
243 heads. Home ported. Shaved .025
224/224 .600 .600 112 lsa cam
fast 90/nw 92
ati 10%
long tubes
yank 3600.
410 gears.
​​​​​​DA was at 2600 ish for both passes.
Air temp 94 degrees 85% humidity
First pass whent 11.81@112.73
second pass whent 11.71 @ 112.50
Edit: second pass whent 11.77
car pulled great till the 1/8 mile then fell on it face. Feels like it's running out of usable rpm with the baby cam. Overall though it ran well considering the horrible track conditions.
Update:
Got another crack at this in decent weather. The only changes are a meziere water pump.
I think this is about as fast as this car is going without major changes.
Old 06-12-2017, 08:26 PM
Z28SteveA4's Avatar
Congrats man! That's a nice and simple setup that is making pretty good power to send a full weight f body close to mid 11's.whats was your 60'
Old 06-12-2017, 08:30 PM
wph351's Avatar
Thanks man. Ran 60' times of 1.64 and 1.65 I think. I'll have to check the slips to be sure. I'll take pictures and post up when I get a moment.
Old 06-13-2017, 02:04 AM
CyberGrey Z28's Avatar
That's a good time but the trap speed seems a little off. What does it run in the 1/8th? Weight?
Post some pics
LS 3gs
Old 06-13-2017, 05:22 AM
wph351's Avatar
Here are the slips of both runs. The mph is disappointing. I was holding the car in 3rd for fear it would shift just before the finish line. I'm thinking I shold have let it go into 4th. It was completely out of steam the final 200 ft or so. I don't know what rpm I crossed at, but it was definitely past a good useable rpm.
Old 06-13-2017, 05:24 AM
wph351's Avatar
https://youtu.be/IZYEju21LCs
Here is a youtube link to the 11.77 run.
Old 06-13-2017, 05:29 AM
wph351's Avatar
Post some pics
LS 3gs
I'm not sure of the weight. It's a fully optioned car and i do have the a/c hooked up. Spare was pulled. I weigh 250 ish.
Didn't I buy some parts off you a while back?
Old 06-13-2017, 09:11 AM
Romulus22's Avatar
My 91' Z28 was around 3300 on the scales and it was a full power car.
Old 06-13-2017, 04:20 PM
wph351's Avatar
Good info thanks. I'd say my car weighs at least that, with the 12 bolt and subframe connectors maybe slightly more.
Old 06-14-2017, 01:49 AM
Looks like a sleeper!! What did the 4th gen have done?
I think it'll do 11.5x once you figure out what's going on in the top end. Is it pulling timing? The DA and heat isn't helping you either.
Old 06-14-2017, 08:09 AM
wph351's Avatar
I'm don't know what all he had done as I didn't get an opportunity to speak with him. His was a manual car, with a drag pack.
I don't know about the timing, I don't have a data logger or any tuning devices. I'm running a basic street tune by Steve Williams at efi performance.
I can only go as quick as 11.50 at my local track before they require cage work and additional safety equipment. I plan on going down in the fall and testing how steadfast they enforce the rules on test N tune sessions.
I'm SURE the weather conditions cost everyone .2 ish that day. The conditions were awful for drag racing.
Old 06-14-2017, 09:25 AM
Hardtop Brian's Avatar
What size tire? I'm running 26" with 3.73 and cross in 3rd at 6200 rpms with a yank ss4000. Probably need a 28" tire for 4.10s if you aren't spinning it high.
Old 06-14-2017, 12:51 PM
wph351's Avatar
Yes sir 26" here as well. I'm lowered about an inch all the way around so I was hesitant to run a 28". It's looking like a gear swap is in my future. The car doesnt feel comfortable on the highway. I'm thinking about 323s or 342s.
what mph are you crossing at?
Old 06-14-2017, 01:07 PM
With stock cam and heads 113.5 with good air. I went low 114 a couple weeks ago with ls6 cam and 2000' da. Should go 116 in good air, but will be really close to shifting to 4th. I liked the 3.42 when I had it.
Old 04-30-2018, 10:41 AM
wph351's Avatar
Bump for update.
Old 05-01-2018, 02:55 AM
Good improvement!
Old 05-02-2018, 02:14 PM
wph351's Avatar
Good improvement!
yep! Pretty happy with how it runs for such a mild build.
Quick Reply: Ls1 irocz first Track run: Updated
