LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   11 Second Club (https://ls1tech.com/forums/11-second-club-87/)
-   -   Will this get me 11's? (https://ls1tech.com/forums/11-second-club/369307-will-get-me-11s.html)
nomorews6 Aug 22, 2005 02:39 AM
I'm thinking about having all this: Will it get me in the 11's at sea level?
front sway bar removed, lid, borla, 4000stall/3.73 gears, skinnies, sticky tires. Will I need much more?
NXZ28 Aug 22, 2005 04:30 AM
You will need a computer tune for the stall and gears. Eliminate the torque management, raise the rev limiter, adjust for firmer shifts, and raise the shift points in the tranny. With your setup you have now, you will probably see 12.60s. That is without any weight reduction besides the sway bar. Good luck.
nomorews6 Aug 22, 2005 08:50 AM
12.60's? At sea level? That sucks. I was hoping to be closer to the 11's with that stuff. Maybe if I get headers and intake?
TA4U2NV Aug 22, 2005 09:31 AM
well, with the mods in the sig, i'd be lucky to hit 11's with a tune, and I got a 4000 stall and 3.73's (haven't ran it at the track yet. still in the shop)
rufretic Aug 23, 2005 08:47 AM
Add a cam and you have a chance. I ran 12.2 with with 3800 stall and f14 cam. I had 3.23s though, I just put in 3.73s and ss4000. I also changed to true duals and picked up a few ponies. I plan to be in the 11s next time at the track.
Mr_president Aug 23, 2005 09:26 PM
good luck bro, i have all the stuff in my mods and i hit a 12.4 spinning out of the hole 1.9 60 foot and i have a vibrating drive shaft launching at 5500 rpms ! i just orderd a new drive shaft and a slp brake control kit and hopeing i will get 11 ... no one told me street and track racing are in the own differnt worlds!! track is alot differnt then street if you launch it anywhere under 4000 rpm youll bog and if you dont have a rear end the truth is good luck getting home cuz after a few runs kiss it good bye with or with out sticky tires cuz wheel hop will get you.
© 2026 MH Sub I, LLC dba Internet Brands
