Help To Go 11's Have A Stock 2000 Ss Automatic Car, Anyone Have Any Good Bolt-on Suggestions To Run Low 12's High 11's Without Using Nitrous And Without A Head Or Cam Change? Getting Ready To Buy Parts And Would Like To Get The Right Parts The 1st Time. Thanks For Any Help. Mike |
headers,exhaust,TC,DRs,little weight reduction,intake,LCAs,tuning,thats should get you close -brandon |
make sure to do your research on the parts above, you dont want to get stuck wiht second rate parts....also when looking into the torque converter your gonna have to get a larger one like 3600 or higher if your gonna make elevens with boltons...just do your hoework before you buy anything....peole on here will be happy to help out |
with my mods in sig- i think if i had more weight reduction (all i have now is !spare and jack, !back seats, and ! front swaybar) i might see 11.9, or damn close to it. or even with ls6 intake and pulley i may see 11.9. you usually need full bolt-ons plus a stall, and sticky tires are a given. very few people get 11's without full bolt-ons but it isn't impossible. |
Originally Posted by MNT1094 Have A Stock 2000 Ss Automatic Car, Anyone Have Any Good Bolt-on Suggestions To Run Low 12's High 11's Without Using Nitrous And Without A Head Or Cam Change? Getting Ready To Buy Parts And Would Like To Get The Right Parts The 1st Time. Thanks For Any Help. Mike Kooks 1 7/8 stepped headers Yank 4K+ convertor LS6 or FAST LSX intake homported throttle body ASP underdrive pulley 3:73 or 4:10 gear LS1 Edit or HPtuners A little weight reduction With these parts you should have no prob seeing 11.99 with decent air temps, most people will recommend these exact parts as well, good luck with your new setup... :cheers: |
I had Lid, filter, SLP maf, smooth bellows, ported tb, LS6 intake, asp pulley, Meziere electric water pump, MSD plug wires, L/T headers, no cats, cut-out, 3.73 gears, slicks/skinnies, tuning and went 12.088 @ 115.45 with the stock TC. Ofcourse my car was a late model 2000 and got 241 heads from the factory. With a 3600 TC I would have hit 11s easy. I also had a BMR torque arm, LCAs, K member, upper/lower A-arms, jack/spare removed, seats removed, floor mats removed on a 1/4 tank of gas. |
| All times are GMT -5. The time now is 02:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
