Is 11's possible with my setup Mods in signature, i'll be running MT ET Streets. I put down 396 rwhp unlocked/375 rwhp unlocked. I don't know the torque #s, the shop said that they had difficulty with the torque reading. My car is full weight. I've gone a best of 12.7@106 before. However, that was with a 1.8 60ft and having mercy on the 10 bolt. Any thoughts? |
I'd say so...Just depends how hard you leave out of the hole. |
yup, should be possible. There's bolt-on cars running 11's so you better! |
yea i would think.........look at my sig and what i run....with a slower 60......i think my clutch was slipping....but im at like 10ft above sea lvl..............thank god |
I ran 11.50's full weight with like another 7rwhp. You should'nt have a problem. Good luck |
should have no problems if you aren't to far from sea level. |
11.70's at 120. take a little weight out of it. |
you should have no problems clipping 11s with that setup - assuming proper traction and suspension. my bolt-on car went 12.2s all day long @ 108-110...you should have a few mph over me on the trap and a similar 60' (mine was 1.62-1.64).. edit: bear in mind the da was ~2,800'. i didn't get the chance to make a pass in sub 85* weather. had i kept the car, i'm positive it would've gone high 11s in sept/nov at us 41. |
Make sure to heat the tires good and have about 16 lbs of air in them cold. You should have no problems making it into the 11's with the new setup. |
I think you should be able to run 11s. Im pretty close and I have a TSP torquer v2, My best time was a 12.2 with a 1.9 60ft at 115mph. If you can get a 1.7 60ft or better I think you should be well in the 11s. I need to get a rearend and a set of M/T before I can see 11s. Good luck, and let us know what it runs. |
11.71 in good air with 339 rwhp at a raceweight somewhere around 3700 lbs. You definitely have the power to run 11s just a matter of putting it to the ground. |
Any updates??? |
I haven't had a chance to go to the track yet. I may go Sunday. |
| All times are GMT -5. The time now is 03:50 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
