Anyone in 12's with....... an engine without LT's, Stall, or LS6 intake? List your mods please. With better tires are 12's possible with my current set up? |
Well, I have an LS6 intake, but it wasn't a choice for me. Still I think I would be 12s without it. https://ls1tech.com/forums/12-second-club/996942-12-74-108-minor-bolt-a4-video.html You probably wouldn't need tires if you didn't have 3.73s. If you can find a track with awesome track prep you could probably runs 12s as is. If not, a pulley would get you there easily. |
I run low 12s, look at my sig. Mods: FRA, lid, !screen, ported TB, MAF ends, LS6 intake, full exhaust (longtubes, true duals), 3.42, Yank 3500, tune and Drag radials. |
Originally Posted by JeaneGrae
(Post 10361870)
an engine without LT's, Stall, or LS6 intake?...
Originally Posted by bene
(Post 10362960)
...Mods:...LS6 intake,...(longtubes)...Yank 3500... |
(Post 10362960)
Originally Posted by JonCR96Z
(Post 10362975)
Hmm. Got reading comprehension? Let's see, w/o LS6 intake/MT ET tires, I ran consistenly 12.6-12.7s. W/O the Stall/gear, I ran consistenly 13.0-13.2s. W/O longtubes/true duals, I ran 13.5s. I hope those gave you some idea.:nod: |
(Post 10362996)
And not only that but I've seen you talk about running low 12s with only 313rwhp, but your MPH would suggest 335-340 rwhp. Hell, my car with 313rwhp/325rwtq was turning 107 MPH. It seems that your dynoing on a very stingy dyno. |
(Post 10361870)
(Post 10362996)
Originally Posted by 3DFORMULA
(Post 10363949)
I am in the 12's without all three of those items. Stock motor with some suspension parts does it for the LT1, and surely should for the LS1.
(Post 10363961)
I run 107 with a stock LT1 motor. I POSITIVELY AIN'T 300 whp. The point was if Bene has a FRA, !screen, ported TB, MAF ends, and full exhaust over what I had when I made 313rwhp, then he should be making more. |
(Post 10364225)
What kind of MPH do you get when you run on regular tires? |
You never have? |
(Post 10364261)
You never have? |
(Post 10364296)
I have done some 1/8 mile passes on the 315 drag radials and gone 82.xx mph. As a matter of fact the first time I got this car to the track with a CAI and cat-back, I was 13.8x @ 102 on a 235/245 street tire. I have ONLY added suspension since then. That is really all I was trying to express, it is not JUST power that make our cars fast, it must be usable power for the good timeslip. So keep on running your slicks and leaving on the limiter and I'll keep running my Coopers and leaving off idle.
(Post 10364296)
And I'm not sure what the DA was, it is not a concern of mine, kinda like the dyno #'s. The DA at your track can very 5000' over a 6 month or less period. That's more than a half of a second difference in your time. When you change or add stuff to your car, it is a very important part of know which direction your going with your mods. |
(Post 10364225)
The point was if Bene has a FRA, !screen, ported TB, MAF ends, and full exhaust over what I had when I made 313rwhp, then he should be making more. :hijack: For the OP, you should get high 12s w/ gears and MT ET streets. |
Watched a stock 02 LS1vette w street tires run 12.8s and a GTO w LS2 only had drag radials and cat back run solid 12.8s both auto trans. |
(Post 10364935)
Have you seen the dyno machine that was used? I have a video of it in my FQUICK link. FWIW, it was on a mobile dyno, enclosed, no fans and through my STALLED AUTO. Also, when I dynoed my car, within that week I went to Memphis and drove the car for 20+ track runs, hotlapping it. I got a best of 12.2 @ 110 timeslip by the end of the day.:D :hijack: For the OP, you should get high 12s w/ gears and MT ET streets. To the OP just take it to the track and see what you run. That's the best way to know if what your doing to your car is helping. |
What is ..... Ok fellas help me out a little bit, what is DA? My next round of mods are STB, Panhard, LT's, Pulley, ls6 intake, and 3200 stall, and possibly a used set of ls6 heads. I already have new shocks/struts and lca's and sfc's....any guess as to where i'd be with adding those mods and a solid launch? I'm in Minot ND |
(Post 10364926)
dipshit That's the most fucking retarded thing I've heard all day. DA has absolutely NOTHING to do with the three first and two second place trophies and checks that I brought home this year. |
(Post 10365556)
Such a mouth. DA has absolutely NOTHING to do with the three first and two second place trophies and checks that I brought home this year. It's a good thing you don't race around here, I'd put you on the trailer in the first round. Heads up, dial in, index, you name it and I got you covered. |
| All times are GMT -5. The time now is 11:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
