Hoping 12s club this year...
OK guys and Gals what you think it will run in the 1/8-1/4 and how much hp you think it has. hopping for 12s,.My car has 273s as of now..The Tracks I run at is 87/149/300 above sea level and it usually mid 70s-high 80s when I run.My car is an 02 Z28 A4 with 42K miles My mods are...Thanks Jimmy...
-SLP Lid
-K&N Air filter
-Smooth Bellows
-TB Bypass
-P&P TB/Bump Stop Mod
-SLP Y
-SLP Loudmouth 1 Catback
-Spare Tire Jack Delete
-UMI Weld In Sub frame Connectors
-UMI Strut Tower Brace
My best time with the mods above is 8.62@84mph..
Theses Mods are gonna be done before I run it again...
-373 Gear
-275X40X17 M/T DR's
-Frost Tune
- Yank 4000 Stall
-Pacesetter Ceramic Coated LT's With TSP ORY With 02 Extentions
Thanks Jimmy..
-SLP Lid
-K&N Air filter
-Smooth Bellows
-TB Bypass
-SLP Y
-373 Gear
-275X40X17 M/T DR's
-Frost Tune
- Yank 4000 Stall
Thanks Jimmy..
The gears and a tune should get you there . Not sure about the frt sway bar delete .I like the way my ride handles .Thats 1 of the reasons I bought a 4th gen F body . I went 13.4 @ 105mph (8.8 @ 83mph in the 1/8) in my 98 Z A4 with 273's ,Magna flow C/B ,and a SLP lid . I did my 373's ,Tune and 315 35 17 D/R's so Ill let you know as soon as the tracks open up and the 2 ft of snow is gone
Removing the sway bar might help as a weight reduction, but I also am not going to take mine off. It can not make that big of a difference.
With gears and the other mods you should be high 12's. Other than LT's and ORY you are where I am at.
Good luck and let us know the HP and TQ when you get it tuned.
How long till your tracks open up?
Colonial beach is better than sumerduck.. My car is faster at colonial beach than sumerduck. Its the next closest track than MIR. Iam gonna run my car till I go get and install the rearend my dads buddy gave me..Test N Tune is usely fridaynight but its the begining of the year they will be fridays the first friday in april..
I just ordered a circle D 3000-3200 Stall and I ordered Pacesetter ceramic coated LT's with TSP ORY with 02 extensions. Iam gonna get frost to tune it. But I don't now if I should wait till I put the 342/373 gear rear end and 160 stat in first before I get it tuned.
My best is 8.62@84.09s in the 1/8th and 13.23@106.11. Iam adding SS4000,373 Gears,DR's/FROST tune.Wounder what its gonna run with the mods Iam adding. But its only one way to find out is to run the car..
When I get back from my family reunion after next weekend. I'am gonna start installing my Stall/LT's/ORY/160stat/B&M Super Cooler with a 29,800 BTU/DR's. I'am woundering if its gonna hurt anything if I drive it around without a tune. I now I won't get the full potinial out of it. I'am gonna get Frost to tune it when he has time.
How much should I pickup after the install of the parts before and after a tune. If its gonna hurt anything running it hard before a tune I won't run it till I get a tune..Thanks Jimmy..
Ok thanks so thats where I'am gonna put mine at then. Mine Idles at 500-550. wounder why so low I can't wait till I install all the parts. Stall/LT's/ORY/160stat/later down the road 373s.
