12 Second Club In the 12s yet? Come inside!
12.3 98 z/28 A4 street car on 275/50/15 Nittos
Old 08-21-2010, 03:44 AM
PACKETFOCUS's Avatar
Default 12.3 98 z/28 A4 street car on 275/50/15 Nittos
Just bought this car last week, and took it to the local track to see what it would do. Ended up running several passes in the 12's, best pass being 12.387.
Reaction .001
60' 1.845
330 5.194
1/8 7.975 @ 88 mph
1/4 12.387 @ 112.00
Car has texas speed cam, ls6 intake, stock throttle body and MAF, stock suspension, long tubes, TCI Super Street Fighter A4, stock 10 bolt w/ 3.73's, OLD nitto 555's.
http://www.youtube.com/watch?v=pcymJ...=youtube_gdata
Drove it about an hour to the track and got 22MPG. Full interior w/ 6 point wolfe weld in cage.
Old 08-21-2010, 06:36 AM
blk/slvr02ss's Avatar
Nice,get those 60ft down and u will be real close to 12.00.
Old 08-21-2010, 08:11 AM
Silver98Ztwentyeight's Avatar
awesome passes, im hoping my times would be the close to the same considering i ran a 8.00 pass in the 1/8th @87.1.
Old 08-21-2010, 04:43 PM
Mike Morris's Avatar
Get a converter in that car!!!!!!!!!!
Nice job!
Old 08-22-2010, 07:46 AM
1Bad97WS-6's Avatar
Nice times Iam hoping to run that when I get my converter/LT's/ORY/DR's/160stat/tune installed..
Old 08-23-2010, 11:52 AM
Thanks man.. The nitto's were real old but hooked the best on that pass. I ordered some MT Drag Radials 275/60/15 so it should hook a lot better.
Also just put a nitrous setup on it and going to test it out wed night.
Old 08-23-2010, 11:57 AM
Thanks man.. the track wasn't prepped but on the pass in the video it hooked better than it did all night. Other passes it was spinning a lot more in 1st and into second a little.
New radials should be in tonight and I now have a 100 shot on it with an FJO progressive controller and MSD timing twister so it should be in the 11's.
Old 08-23-2010, 11:59 AM
Nice job!
Thanks dude-
It does have a convertor. I was told its a 3600 TCI that came with the TCI super street fighter 4l60e. It was to start flashing/pulling around 3k on the foot brake so I think its a little tighter than 3600.
I haven't looked at the tach between shifts so see what the RPM drop is at WOT, but it seems to be in the power.
I will have a small kit on it when we go back wed night.
JP
Old 08-23-2010, 10:34 PM
When you get those M/Ts try powerbraking at 1100-1200 and flash it on last bulb. Using that with a 3800 I always hit at least 1.70-1.63 with those tires. You will need to experment with psi. I play it safe and run 25 psi since I have a stock rear.
I bet you get in the 11s first pass if air is decent
Good luck and kick *** with those tires.
Old 09-18-2010, 10:47 PM
mtank's Avatar
how big is the cam in that car? i ran a 12.51 @ 107 @virginia motorsports park about this time last year. i have a 3k stall ptc smooth bellow slp maf & spintech prostreets & still has stock 3.23s. still have factory exhaust & wheels running 275/40/17 nitto d/r though. my 60 ft on that run was 1.72 & ran 7.94 in the 1/8th.
Old 09-19-2010, 08:11 PM
79TAKid's Avatar
Nice reaction time for a pro tree lol
