12.09 w/bolto on's
A good CAI would most likely get you into the 11's. Since you have the AC removed the SSRA Mega Mouth would bring in a lot more air. The Mega Mouth is similar to the regular SSRA, in that it has a scoop, however it's much larger since people with no AC have removed the condenser. This frees up a lot of room.
They definitely serve there purpose in drag racing
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Take some weight out and your 60' will drop. My 60' dropped from 1.7 to 1.6 by taking out around 150lbs or so. The times in sig are in +500 DA on 275 40 17 zr1s all around and mt drs in the rear.
Dont underestimate a good cai kit. I really like the ssra. I have ssra megamouth coming on fri seeing how I deleted my a/c. I will have 11s in the fall no problem.
