dissipointed 12's Car did 12.1 @112, Spun out of the hole and bounced of the limiter on 1-2 shift. it was hot as hell though. LS6 ported heads 232/236 114 lsa cam ls6 intake 3600 9.5 billet converter with performabuilt stg 2 4l60e 10 bolt 4.10 gears. Will upload video later |
if you spun alot,and there was really bad air out ,thats not to bad, suspension mods?tires?what did you launch at? post your time slip up as well |
BMR subframe connectors, lower control arms torque arm panhard bar lca relo, front sway bar, all adjustable. Tires are nitto NTO5r 275/40r17 Launched at like 2300. Will do if I can find it, going to get fm4! |
Seems to b running better or should i say shifting better !!!!!what was your 60 ft ? That was a good time for the heat and it will b in the 11's when it cools down !U Need to come out @ 1000 rpms and flash the converter ! |
Joe you have to come out next time with us |
Yea let me no and i will come out and take my bike i just bought and run it and maybe hit 9's if i learn how to launch it !!!! |
haha nice, maybe next week |
Sounds like that thing needs to shift alittle higher into second gear, other than that looked like a good clean pass. |
Originally Posted by 1998MysticZ28
(Post 15494952)
Car did 12.1 @112, Spun out of the hole and bounced of the limiter on 1-2 shift. it was hot as hell though. |
| All times are GMT -5. The time now is 05:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
