1st time out 12.53@112
My Camaro was an 01 so it came with the ls6 intake. Best performance with the stock stall will be just off of idle, make sure you stage as shallow as possible. I like to pre stage then just repeatedly pump the brake until I blip the full stage bulb. It can make a big difference in 60 times. And in my opinion running mickeys would slow you down. You don't need the extra stability they offer for the power you're at and they are heavier than the toyos, which I will stand by are the best daily duty tire that still hooks good at the track. They get way stickier than comparable nittos if u ask me. U could raise the shift points some, mine were still stock setting before I sold the car. 6200 would make a difference. Are you hitting the rev limiter at all?
1k is not bad, I wouldn't trust a 2500 launch with the 10 bolt but A4s tend to put the power down smoother than an m6. You could definitely hit 11s with weight reduction and I would say a better converter (although I'd personally do a cam swap with a new converter)
hey guys can anyone take a guess at what my 1/4 mile will be with adding the yankss4000? my car 98 Camaro ss 55,000 miles long tube headers,ory,gmmg cat back, slp lid,fast 92 intake 92tb, 3.73 gears, sfc,lca,lca relocation mounts. drag radials.
my last run was without the stall 13.1 @107 at a horrible track and my trans was way to hot it wouldn't shift from 2nd to 3rd without me letting off the pedal any input appreciated
If you can hook that's a combo for high 11s there is a few on YouTube doing it less the fast intake. I have a stock stall, and a ls1 intake with garbage 1.98 60' I pulled this 12.5 so I know you could too. My car was Dyno tuned and only made 341hp/356 tq
#35
great info awesome vids.. did you do a underdrive pulley? or cutout those are the only other power adders I don't have an do you know if a cut out will do anything for me since I have
ORY no cats but I do have gmmg exhaust
