Notices
12 Second Club In the 12s yet? Come inside!
First time in 12's... and went deep
Old 10-23-2016, 08:28 PM
rybern's Avatar
Originally Posted by 30thanniv View Post
Did you happen to run it with the exhaust prior to the Torque convertor and get a better than 2.0 short time.
It would really help to better differentiate the gains from the mods in more sequential order
I never got better than a 2.0 60' until getting the converter. I also did converter and DR's at the same time. These two mods alone took me from 2.0 with 13.0 to a 1.7 and 12.27.
Let me know if I need to clarify more than that. I'll be happy to try.
rybern is offline
Old 10-23-2016, 08:32 PM
pozesd99''s Avatar
What gearing does your car have?
pozesd99' is offline
Old 10-23-2016, 08:56 PM
rybern's Avatar
3:23 gears.
rybern is offline
Old 10-24-2016, 09:41 AM
Originally Posted by rybern View Post
Did you run low psi with the 555r's? I'm hoping that I can hook with them. I got on it today from a roll and chirped the tires from 1st to 2nd(something that has never happened with my TQ's).... not a good sign.
I did. As mentioned before, 17psi and a looooong burn out before I saw any improvement. Decent street tire though.
Hardtop Brian is offline
Old 10-24-2016, 12:24 PM
30thanniv's Avatar
Answered what I was debating. Ordered my convertor today.
Thanks
30thanniv is offline
Old 11-05-2016, 11:10 AM
rybern's Avatar
I added a drag pack with 555r's in the rear. I also removed the front sway bar. DA is much lower than on previous runs. ~500-600 last night vs 1800 previously. Car ran VERY consistent E/T's but I never truely dead hooked like I did on the Toyo TQ's. Could have a bit to do with lower track temps but probably has a bit to do with the tires. Looking back, I should have done a bit more burnout on these 555r's. I was really hoping to go sub 12's, but never quite made it.
rybern is offline
Old 11-05-2016, 01:57 PM
Jtm2085's Avatar
Nice meeting you last night, your car runs good!
Jtm2085 is offline
Old 11-05-2016, 02:07 PM
rybern's Avatar
Nice meeting you too Josh. Thanks. Back at ya Mr low 11's.
rybern is offline
Old 11-05-2016, 05:24 PM
murphinator's Avatar
you cant get much closer to 11's ! and with how consistent you are pass to pass I bet you get it next time. Nittos typically need more burnout than other dr's so I bet your correct on that as well.
murphinator is offline
Old 11-05-2016, 05:53 PM
98CayenneT/A's Avatar
Damn nice times bud
Ya, the 555r need some serious heat
98CayenneT/A is offline
Old 11-06-2016, 09:54 AM
rybern's Avatar
Thanks fellas. I knocked off exactly .2 and gained 2 mph my best previous E/T's. But I was really expecting to go sub 12.
Things that helped gains:
~1200 reduction in DA
drag pack reduced 60lbs
front sway bar removal
Hurt gains:
harder tire compound
cooler track temps (~ 50 deg on last pass)
What do you think was the largest contributing factor in these gains? DA or weight reduction?
rybern is offline
Old 11-06-2016, 11:50 AM
  #32
I would say da. I've read that 1000' reduction in da is good for .1 or 10hp. With that said, 60lb reduction isn't going to give you 2mph, but it helped some of that (.05 maybe?).
Old 11-06-2016, 12:46 PM
  #33
rybern's Avatar
But its 60lbs of rotating mass and 44lbs of it is off the front end.
rybern is offline
Old 11-06-2016, 12:59 PM
  #34
it's really hard to say, too many things changed. The only thing you know for sure is that what you did plus da was good for .2 And 2mph. You can try to calculate previous runs and these runs to 0 da and possibly get a ballpark of how much the non-da changes affected things.
Old 11-06-2016, 01:58 PM
  #35
rybern's Avatar
Good idea. But I've only found a calculator that goes down to 1200 DA. My [email protected] was at 1800 DA which would calculate to [email protected] at sea level. Not sure how to convert the [email protected] @ 500 DA to sea level.
rybern is offline
Old 11-06-2016, 02:00 PM
  #36
Here you go. Find your track, date, and time closest to run. http://www.dragtimes.com/da-density-altitude-calculator.php
Old 11-06-2016, 02:34 PM
  #37
rybern's Avatar
Here you go. Find your track, date, and time closest to run. http://www.dragtimes.com/da-density-...calculator.php
It appears that you are correct Brian.
Previous run of [email protected] at 1800 DA converts to [email protected]
Friday run of [email protected] at 500 DA converts to [email protected]
So this calculation seems to lean toward DA being the largest factor of my gain by a long shot. This also seems to suggest that the drag pack and front sway bar removal didn't really benefit my car much.
rybern is offline
Old 11-06-2016, 02:50 PM
  #38
.05 was a pretty good guess on my part . Let's say you didn't make those changes and you add that .046 in. Now you're looking at 12.07. Every little bit helps. The only thing you were missing to run 11s was the toyos. I've read that you lose .1 in the 60' as soon as you spin a little. I went from 1.62 With a slight spin on the toyos to a 1.52 dead hook on slicks. All in all, I'd be happy with .05 from what you changed. Get it to hook and you'll be 11.90
Old 11-06-2016, 03:00 PM
  #39
rybern's Avatar
I appreciate your responses man. Makes sense to me.
BTW, race weight this time was 3440.
rybern is offline
Old 11-07-2016, 01:03 PM
  #40
Firebirdmuscle's Avatar
Nice times, there right on par with the mods. Great job with everything and keep chipping away. Good suspension is a main key to bolt on cars' success. You still have a good bit you can bring that 60' down. You do that and that et will fall dramatically.
Firebirdmuscle is offline
Quick Reply: First time in 12's... and went deep
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
