Got 12's I know it's not an LS1 but I'm still happy with the numbers :) 12.61 @ 108.6 ! Not bad for a bolt-on only no heads or cam LT1 ! |
what bolt ons do you have? what gears are you running? do you have any weight reduction? just curious I'm running about the same with shit loads of mods. Also what was your 60 ft? |
No weight reduction other than running weld racing (big's & litttle's). I have not had a chance to run the car at the strip since I had my PCM tuned by ed wright. I suspect the car would go 12.50's for sure and maybe a 12.40's with the right air temp. 1996 WS6 Ram Air (6spd) #1073 Motor: K&N, ASP UD, CAGS !, AIR !, 52MM Holley, 75 MM GMS, Polished bookends, MSD Digital 6, ST, MSD 8.5MM, NGK TR 55, B&M Ripper, Meziere, CC 1.6 RR, FLP Longtubes, FLP ORY, B&B Tri-Flo, Moser 12bolt, 4:11's, T/A girdle, McCloud Street twin, MM DS, Race Prepped T-56, Fastchip's PCM. Suspension: Full BMR (Front & rear swaybars, Strut tower, Subframes, Torque Arm, LCA's, Panhard, safety loop, battery relocation kit) Russell F&R lines, ES mount, Eibach sportline's, Air Bag, HAL 12-way's Wheels: Dazz motorsport rims: 18x9 Fronts (275/35/18 MPS) 18x10.5 Rears (335/30/18 MPS) |
I believe your 323rwhp is the current bolton dyno record, but I plan on taking that away from you :). So far I put down the numbers in sig with 1.7rr's Jet Hot LT's Stock Descreened Maf LT4km Cutout on the stock 2.75" exhaust. A/F was at 12.4 when I dyno'd. You can see the dyno in the link in my sig. I'd like to compare your graph to mine if you have it. I am going to be getting some software to dyno tune the car in the next few weeks and I just did the TB bypass. Pretty basic stuff. Wish I had the dough for pullies, throttle body and an ignition. I really think 330rwhp is attainable from a full bolton lt1 with the right parts. |
Freak LT1, last count I had the record for a bolt-on car (LT1) was 331 rwhp / 347 rwtq I think that is the record ? I have never been able to verify this number. My 323 rwhp / 343 rwtq was made before I had the PCM tuning and no cut-out, so If you wanna take that away from me it's probably gonna take at least high 320's rwhp & high 340's rwtq to get me :) I think with the current PCM tune and cut-out I'm probably real close or a little more than 330rwhp and I'm guessing the rwtq is about 350. Good luck to you on your quest for HP ! Oh yeah, I almost did the 1.7 RR like you have on your car. I think that mod would be good for another 7 to 10 at the rear :) |
| All times are GMT -5. The time now is 03:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
