12 Second Club In the 12s yet? Come inside!
first time running 12's
Old May 4, 2005 | 11:13 PM
phoenix's Avatar
Default first time running 12's
i hit a 12.50 at 108mph i was just woundering isnt my et really low??
i thought it should be around 110 for a 12.50. what can i do to get my et speeds faster? i always lose when i hit 3rd gear (A4)
i have cam, ls6 intake, full exhaust.
thinking about adding 3.73 gears but i dont want to lose what little top end power i have.
Old May 4, 2005 | 11:31 PM
sleeperstyle's Avatar
tuning? i'd say low mph for your modifications, but if you hook really well then 108mph is about right for a 12.50. also weather conditions and elevation?
Old May 5, 2005 | 06:57 PM
phoenix's Avatar
i hooked pretty god. 1.7 60 foot. it has a tune but i need to redo it. i have different heads (from mti to stock ) i live in sunny south fla. it was very hot and wet that night. rained all day but cleared up just in time for the races.
Old May 8, 2005 | 12:26 PM
Phoenix 2001's Avatar
What size cam is it?
Old May 8, 2005 | 12:30 PM
You won't lose top end power, you will gan it with 373's. You will lose a little top speed though, but how often do you drive over 140mph lol. If you really want to wake your car up you should get a pair of AFR heads.
Old May 8, 2005 | 12:32 PM
Also since you have a bigger cam you should look into getting a bigger throttle body, like a 78mm or 80mm.
Old May 9, 2005 | 07:07 PM
99SSLS1's Avatar
Is the tm removed, that helped my doggy feeling in 3rd.
Old May 9, 2005 | 08:53 PM
phoenix's Avatar
i have the comp cam 581 left 224 intake and exhaust 112 or 114 i dont remember, i want to put a good pair of heads on but too much money right now.
what is tm???
i got my nitrous install last firday so i am going to see what i can run with a 75 shot.
