i think i'm tapped out on this setup..
UNPREPPED TRACK
1.715
7.818 @ 87.09
12.330 @ 108.60
engine - whisper lid, coated pacesetters w/3" x + 4x9 magnaflow dumped @ axle, ls6 intake, 160* t-stat.
stock tranny - fuddle 4k/2.4 stall. transgo "full race/high stall" shift kit, b&m deep pan, b&m 24k cooler, poly mount.
stock rearend - strange 373 gears, t/a cover. stock rims all around, bfg DRs out back.
suspension - spohn LCAs, KB DD sub-frames, !front swaybar.
computer work - shift points tuned, !tqm, !air, !egr, !rear 02s.
weight reduction - removed front/rear bumper support, spare tire + jack, front swaybar. car weighs 3,320 empty. i weigh 200, making a 3,520 raceweight.
the car danced off the line from tirespin, so i know i could knock probably another tenth and a half off if i hit a prepped track, assuming i would 60' somewhere between 1.61-1.65.
any ideas on what a good engine tune will get me? i'd like to see 11.99999999999 with a tune and prepped track before i drop in my ginormous custom ground cam.
1.715
7.818 @ 87.09
12.330 @ 108.60
I have basicly the same setup as you....First time out at the track with the new stall I cut a 1.71....and that was barley stalling it off the line 1000rpms....
1.6s should put in the 11s...
I went 12.3 @ 112 last year with the stock stall....with a 1.83 60`
