12 Second Club In the 12s yet? Come inside!
Will 3.73s,stall & DRs ONLY get a 4th gen into 12s?
Old 07-23-2006, 04:57 AM
Z28XTC's Avatar
Default Will 3.73s,stall & DRs ONLY get a 4th gen into 12s?
Like the heading says and when I say only I mean nothing else.
Old 07-23-2006, 08:48 AM
Ryan_Z28's Avatar
depending on the size of the stall and your DA id say yes
Old 07-23-2006, 01:49 PM
Z28XTC's Avatar
Say 3500 stall and whats a DA?
Old 07-23-2006, 02:26 PM
c6_dave's Avatar
density altitude... weather and altitude
Old 07-23-2006, 09:37 PM
s346k's Avatar
i've seen a lid, 4k stall, and DRs get an otherwise TOTALLY stock 01 SS into the 12s.
he was runnning 12.60s @ 105 i believe...with low 1.7x short times.
Old 07-23-2006, 10:58 PM
burnzilla's Avatar
Run The God Damn Car
Old 07-24-2006, 08:08 AM
Z28XTC's Avatar
First chance I get.
Old 07-24-2006, 03:11 PM
camscam02's Avatar
look at sig!
Old 07-26-2006, 12:10 AM
Z28XTC's Avatar
so if you had 3.73s you would be 12.4s?
Old 08-02-2006, 01:49 PM
john shea's Avatar
My times in Sig without a stall so yours should be better.
Old 08-03-2006, 04:53 PM
Roarin_8's Avatar
Launch the car hard and you may get a high 11 with those gears and stall.
Old 08-04-2006, 10:18 PM
sixvi6-camaro's Avatar
yup.. I can see that because I did a 12.68 @105 with 1.7x 60's in my car with just the mods in my sig (Also A Basic tune Form Speed Inc) and DR's with a bit of basic weight mods (taking out rear setbelts and seats, front sway bar, jack, spare, my sub and amp) that was the 2nd run of the day with upper 70's air temps and got worse as the temp and humidity climbed. Also there was another 2.73 gear Ls1 camaro with a TCI 3500 no tune with a lid and an open cutout running 12.9x's at 102. so with those mods it should be 12's no problem.
