LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   12 Second Club (https://ls1tech.com/forums/12-second-club-86/)
-   -   trying for 12's with an a4 ta (https://ls1tech.com/forums/12-second-club/644428-trying-12s-a4-ta.html)
98BlackTransAm Jan 21, 2007 04:33 AM
i'm goin to the track sometime in early march, and i have a 98 a4 with 2.73's, cut-out, lid, filter, tranny cooler, and a 3400 stall (2.1 str) on yokohama street tires. i kno every car varies but do you think i'd be able to reach 12's with this set up?
thanks
presto_z Jan 21, 2007 10:57 AM
since you have the stall yes.... if you can manage to get traction..
arctic00z28 Jan 21, 2007 11:09 AM
Not without some Drag Radials.The best I could manage was a 13 flat on street tires.Mods are pretty similar.Good luck!
som6969 Jan 21, 2007 06:43 PM
My friend cut a 12.96 on street tires. He's got TSP True duel exhaust with bullit mufflers, Hypertech powerprogrammer, SLP Bilstein shocks and whisper Air lid. Well the tires are Nitto 555's. But it was still a great time with out a stall.
5_02ls1 Jan 27, 2007 09:44 PM
loose the 2.73s your very likely to break somthin with that hi of a gear.if you hook up.
Armyman2445 Jan 27, 2007 10:35 PM
Actually if he hooks he's less likely to break his rear end at all. If 3.73 or 4.10's are used the life of a 10 bolt rear is reduced two thirds with tires that hook. I ran in mid 11's with 2.73 and an A4 cutting 1.5 60ft's. IF the transmission is stock the transmission will break before the rear. Due to the high gearing of 2.73's with sticky tires, it puts all the stress on the transmission instead of the rear.
99Silverado5.3 Jan 28, 2007 01:33 PM
thanks
I say yes if the track is working
98BlackTransAm Jan 29, 2007 05:15 PM
yeah the 3.73's and 4.10's will launch harder from a dig. I kno someone who switched 3.23's for 3.73's though and they got the exact same e.t. and trap speed as before. I've never done a gear swap personally so I don't really know, but it seems new gears don't help as much as they're cracked up to. right now i'm trying to decide between BFG dr's or Eagle f1's just to ensure my car's ability to run 12's. thanks for the input. ;)
98ls1blackbird Jan 31, 2007 07:43 PM
thanks
I run a very similar setup that you have, but no cutout. I have a 98 TA, A4, 2.73, lid, Vigilante 3200, LCA's and panhard bar with BFG DR's. My best is 13.23 at 102.5 mph with a 1.80 60'. I dont make the horsepower most guys do as my mph clearly shows that. Good luck with your attempts to crack the 12.s.
© 2026 MH Sub I, LLC dba Internet Brands
