12.8 @ 117.5 w/ 245's
title change please.
running CRAPPY *** 245 street tires and got a 2.39second 60'
i'm running the MS4 cam, stock heads, ASP pulley, QTP race headers, LMR custom true duals w/ ORX and borla XR-1's, p/p throttle body, ls6 intake, and lid w/ K&n filter
trapped a consistent 117 and made three passes getting better times every round....shifting at 6400.
fastest run was 12.8X
as soon as i get a rear end i'll throw the MT's on~!
1 Post
I'm just guessing you should be in the 380-420 RWHP range and should be touching 12.0's. . .just guessing. . . Sounds like traction is an issue. . .ESPECIALLY with 2.39 60's
awsome trap speed! throw some m/t's on it and head to the track. your rearend should be ok if you go easy off the line. if you want to strengthen that 10-bolt a little, put a TA diff. cover on it. you can preload bearing the caps. good luck
i'm totally paranoid about blowing my engine.
i've heard mixed reviews about MS4 PTV contact(way after i installed mine) and havn't had a chance to pull the heads yet and flycut.
so in my own little world, i believe that not spinning as high puts lets stress on the crank bearings, rod bearings, etc and allows for less chance of detrimental interference...henceforth preserving my valves/pistons/pushrods
....really i just need to pull the freekin heads and quit whining!
