mid 12s from H/C a4
mid 12s from H/C a4
A couple of weeks ago I got my car tuned and went to the track to see how much I gained. It went 12.52 at 112 mph. Not to bad for a stock stall converter is it? Dont worry, I have a performabuilt lv2 with a 3400 stall on their layway plan. What do you guys think it will run after I get the new tranny in and some better tires?
Well I just orderd a level 2 with a 3600 stall yesterday and I plan on spray after I get a better rear end, no more than a 150 on the stock bottom end. When I was talking to Frank at performabuilt I told him I plan on spraying and he told they will built the converter anound NA use and it would only flash about 150 rpms higher on the bottle. Also does anyone know what the shift extentions would be with that converter?
thats damn good! you got so much unlocked power waiting to be unleashed! I ran a 7.99 with a 1.73 60ft(walked it out and then nailed it) and thats just with a Yank 4000 stall,long tubes and true duals with DR's that would not stick,no tune and stock block,cam,intake,TB,heads and full weight 02' WS6! your car like alot of H/C/I and full exhausted cars with good tunes will hit low 7's 1/8 and low 11's 1/4 but with a great tune could easily hit 6.9's 1/8 and high 10's in the 1/4!!!! good luck!
R/T .102
60' 2.055
330 5.405
1/8 8.125
MPH 90.320
1000 10.505
1/4 12.521
MPH 112.09
Here is the 1.87 sixty run
R/T .323
60' 1.873
330 5.252
1/8 7.991
MPH 90.080
1000 10.379
1/4 12.526
MPH 111.70
That 1.87 sixty foot was a one time deal that day. I was averaging around 2.05. Here is the time slip from my best run.
R/T .102
60' 2.055
330 5.405
1/8 8.125
MPH 90.320
1000 10.505
1/4 12.521
MPH 112.09
R/T .323
60' 1.873
330 5.252
1/8 7.991
MPH 90.080
1000 10.379
1/4 12.526
MPH 111.70
R/T .102
60' 2.055
330 5.405
1/8 8.125
MPH 90.320
1000 10.505
1/4 12.521
MPH 112.09
R/T .323
60' 1.873
330 5.252
1/8 7.991
MPH 90.080
1000 10.379
1/4 12.526
MPH 111.70
you know I thought the same thing when I first got my LS1(was racing stangs for 15+ years before the switch to the "darkside") but the stall is the #1 performance go-fast mod other then nitrous of course and the ET's don't lie! you have all that power bottled up with a stock converter,it's bad enough on a factory stock car much less a H/C/I one!
I'm still on the stock LS6 intake so there is one more thing to get more ponies. I dont know what one I'm gonna go with. I'll just have to wait to see some results from that street warrior intake that is supposed to release some time this spring. But I need to get a 9 inch and some stickkies first before I go adding more power.
Hell I probly will be required to have one because I thing 11.5 or faster you need one. Its an IHRA track here. And if I dont run faster than that on the spray I'll be pissed unless its something like a 11.51 at 125+ MPH due to no traction
