Will I hit 12's? I have a 98z28 with: Hooker Long tubes 3 inch y-pipe corsa exhaust 373 gears 160 termostat Going to get a SLP lid and a 80mm TB Also have a Hypertech programer 3 I have Boyd 17's with full weight car. |
Is the car a M6 or A4. Being that your car is only a 98 and has the LS1 intake manifold, I would not waste the money on a new throttle body until you get a LS6 intake manifold or even a FAST 90/90 setup and if you go LS6 manifold I would just do a stock ported and polished throttle body. As for running 12's it is always possible. People have gone 12's with a completely stock car with only putting drag radials on. |
You should hit 12's if you're an A4. You have more mods than I did when I broke into the 12's. If you're an M6, I'd guess it will depend on your driving. |
You should be able to hit 12's depending on weather, track conditions, and driving.... |
Originally Posted by josh2002-ws6
(Post 8299752)
Is the car a M6 or A4. Being that your car is only a 98 and has the LS1 intake manifold, I would not waste the money on a new throttle body until you get a LS6 intake manifold or even a FAST 90/90 setup and if you go LS6 manifold I would just do a stock ported and polished throttle body. As for running 12's it is always possible. People have gone 12's with a completely stock car with only putting drag radials on. Thanks |
Originally Posted by turbopaez
(Post 8304297)
The car is a A4. Okay so no TB, so the LS6 intake flow more? Is the Fast 90/90 a intake ( sorry new to all this)? Thanks |
Well I would only get the FAST 90 intake manifold and Nick Williams throttle body if you are going to go with heads and a cam. With the stock heads and cam or even stock heads and aftermarket cam the LS6 intake will be just fine. The 1998 to 2000 LS1 F-bodies came with the LS1 intake manifold and the 2001 and 2002 LS1 f-bodies came with the LS6 manifold. The LS6 manifold flows way better then the LS1 does. Now that knowing your car is a A4 You should go with a new Converter with a higher stall. How streetable do you want the car to be and how fast do you want to go at the track? For a nice streetable car I would not go any higher then a 3000 to 3200 stall. |
Thanks guys, yeah i'd like to keep it streetable. I have read alot of people using the tr224 cam. |
If you want to stay streetable I would say a nice stall converter at about a 2600 stall to 3200 stall should be great for you and the TR224 is a very nice cam for street applications. The LS6 intake manifold with the stock ported and polished throttle body would most likely be your best bet with that cam and your stock heads. You might also wanna think of doing some suspension work to the car like, lower rear control arms, torque arm, subframe connectors, and maybe some nice adjustable shocks in the front. Spohn is a good place to find the suspension parts and QA1's are a good brand of adjustable shocks. The suspension parts sometimes get you the best results when at the track. A good suspension setup is need to make all of your power transfer and get good times with out spinning. |
Thanks for all the help. |
You should hit 12s with any kind of traction. Those 224 cams are pretty streetable, and definitely get the LS6 intake. |
my Yank 4000 stall is very streetable!:D |
Hey Turbo, have you tooken the screen off of your Mass Air Flow Sensor. It pops right off and gives you that extra power. No lights come on or anything. On the Z28 you have, people cut the bottom plastic, thats in the air filter, just enough to get extra air into the engine. The Z guys also take off the front black plastic cover thats by where the license plate is and replace it with a grill. That pushes more air in through the bottom of the air filter. Remember to lower the pressure on your street tires to about 16-18 psi. and take off at idle the first time your at the track, or else, depending on your tires, you will stay there spinning. Keep me posted! |
Originally Posted by fastvet
(Post 8320773)
get a lid, doesnt matter which brand, they should all cost around $100. look in the for sale section on here. You will hear arguments about de-screening the MAF, some say do it, others say dont. i say leave the screen on, if you wanna do without a screen then get an aftermarket MAF, so you can put your stock one back on if you dont like the other one. im shooting for 12s with what i have in my sig. traction will be your biggest problem. you need to get down technique for feathering the throttle at launch. i am yet to launch on DRs, next time i race ill be on them so ill see. |
Originally Posted by Omega Doom
(Post 8320027)
my Yank 4000 stall is very streetable!:D WOW I am hopping you are joking. |
M^ can do 12's in stock form. A4 with your mods should easy. |
(Post 8335891)
I would think you can get a any size stall if you get a lockup one and be streetable. |
(Post 8335891)
| All times are GMT -5. The time now is 03:49 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
