12 Second Club In the 12s yet? Come inside!
I made the 12's in a stock A4 Camaro
Old 07-15-2008, 08:05 AM
1969mach1's Avatar
Default I made the 12's in a stock A4 Camaro
with a little 100 shot...
The car ran a 12.29 @ 119mph with a 2.11 60' on street tires ( not DR's ).
It's a stock A4 with a Cold Fusion wet kit. I was spraying a 100 shot with low bottle psi around 875, plus air/fuel ratio was a low 11.5 on the spray.
I think with a good custom tune, good bottle pressure and a set of M/T DR's the car should be deep in the 11's.
Old 07-15-2008, 08:32 AM
animuL's Avatar
Seems pretty good, same mph as me on the 100 shot but I bet yours will go down some with a better launch. I dunno about deep 11s with a tune but you'd be in the 11s for sure. GG!
Old 07-15-2008, 11:32 AM
MYSTIC-1SC's Avatar
nice track numbers.
Old 07-15-2008, 03:09 PM
z28_YOU_HO's Avatar
nice numbers for sure!
Old 07-15-2008, 05:44 PM
jetlag's Avatar
That is a good mph!!
What gears are you running? When are you spraying? Bump that bottle pressure up to 950-1000.
Old 07-16-2008, 12:40 PM
1969mach1's Avatar
when i stage i bring the rpm's up to 1000. then lift off the brake and roll into the throttle to where im at full throttle at the 60' mark. the nitrous is set on a wot, so it starts to spray as soon as im at full throttle. so it's spraying through all the grears, all the way down the track.
next track meet I'll have a set M/T DR's and will be spraying out of the hole.
Old 07-18-2008, 09:06 PM
krazy4's Avatar
Nice job man!!!
I am going to pretty much have that same setup here in about 1-2 weeks.
Hope to get the same results.
Old 07-18-2008, 09:31 PM
Blue_00_WS6's Avatar
nice good job
boola1341's Avatar
Congrats. You'll be posting in the 11 second club soon.
Old 07-27-2008, 09:20 PM
BigZee71's Avatar
^^ Or in the transmission section!
Jk nice times man. When you say spraying out of the hole, are you going to go with a window switch, or manually activate the solinoids?
Old 07-27-2008, 10:30 PM
therealcreeper's Avatar
that is impressive. what made you go with a wet kit and not dry?
Old 08-01-2008, 05:33 PM
Dave 96TA's Avatar
dry = upgrading the fuel pump which is a PITA
Old 08-01-2008, 06:17 PM
FC_LQ4's Avatar
damn, 119mph with just a 100shot? the 4l60e is stock too? hell yea!!! this is what i like to see!
Old 08-01-2008, 09:17 PM
1969mach1's Avatar
now if I can get 60' down I should be in the 11's with that MPH.
Cold Fusion had a sale on the wet kit. Plus i can tune the air/fuel mix by using different fuel jets.
Quick Reply: I made the 12's in a stock A4 Camaro
