Advanced Engineering Tech For the more hardcore LS1TECH residents
Compression ratio help
Old Jan 31, 2009 | 01:47 PM
dubrado's Avatar
Default Compression ratio help
iron 408, 4" stroke, 4.030 bore, and 71cc chamber was 10.5: 1 roughly
-8cc piston
What would it do with a 64 cc 243 head?
also, if I milled that down to 61cc or lower what would it be?
If it's milled down 0.030 or 0.020, will it have PtoV problems on a TSP giant cam?
thanks again for all your help gusy
Old Jan 31, 2009 | 01:55 PM
Bouvs's Avatar
what gasket thickness?
These are all with .055 gasket thickness
64cc's = 11.8:1
61cc's = 12.2:1
Old Jan 31, 2009 | 01:58 PM
Bouvs's Avatar
Also if you're going with flat pistons I would assume that you will have major PTV clearance issues with that cam but I'm no expert...
Old Jan 31, 2009 | 06:27 PM
dubrado's Avatar
sorry, forgot to add that, -8cc piston.
