Advanced Engineering Tech For the more hardcore LS1TECH residents
Cylinder Honing
Old Jul 25, 2009 | 02:39 PM
Petraszewsky's Avatar
Default Cylinder Honing
Which is better for honing stock Iron LS2 Sleeves?
Silicone Carbide or Aluminum Oxide?
I plan on using 320 grit of whichever material that will provide the best hone...Any opinions?
Old Jul 26, 2009 | 09:35 PM
I just went ahead with the Silicone Carbide because of it properties over the Aluminum Oxide...
Old Jul 29, 2009 | 08:35 PM
racer7088's Avatar
Depends on what stones they are. We use both. Are you talking Sunnen?
Old Aug 3, 2009 | 12:03 AM
I'm using a Flex-Hone with the globules...I've read that it provides a better cross hatch pattern...
Old Aug 3, 2009 | 05:29 PM
I tried the Flex-Hone out today to see what it would do...I'm pleased with the results..I do have to go over the two cylinders some more though...
Attached Thumbnails Cylinder Honing-img_3972.jpg   Cylinder Honing-img_3973.jpg
Old Aug 16, 2009 | 04:18 PM
How much can you take off with honing and still use stock piston rings?
Old Aug 16, 2009 | 04:24 PM
racer7088's Avatar
not a whole lot and not usually enough to get everything cleaned up but half a thousandth to a thousandth has been done quite a bit by quite a few people. Just depends on how bad your cylinders are already.
Old Aug 16, 2009 | 05:32 PM
It's just Cylinder #7... everything else is cleaning up nicely....With about thousandth of room to play then I should be completely fine....I'll just have to take my time....
Old Aug 23, 2009 | 05:41 PM
Does anyone know the ring end gap specs for stock LS2 piston rings? Also on cylinder #7 the pitting can not be caught be a fingernail..But you can feel it with your finger tip...How adversly will this affect piston ring sealing? And how much would I be looking at to have a shop hone that one cylinder? Can you help me out ASAP?!?!Thanks for you replys..
Old Aug 23, 2009 | 09:21 PM
racer7088's Avatar
Arrow
I can't really see anuthing so I can't tell you anything for sure but if you can't feel it or it is subsurface you shoulc be fine in general.
Old Aug 23, 2009 | 09:57 PM
I'll post up some pics tomorrow...But until then does this sound about right for the stock rings? I'm not a professional engine builder by any means so thanks for all the help...Oh and for the 1st and 2nd compression rings do you know if the dot faces upward or downwards on both?
Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Production
0.20-0.41 mm
0.008-0.016 in
Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Production
0.37-0.69 mm
0.015-0.027 in
Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Production
0.22-0.79 mm
0.009-0.031 in
Old Aug 24, 2009 | 08:22 AM
racer7088's Avatar
0.20-0.41 mm
0.008-0.016 in
0.37-0.69 mm
0.015-0.027 in
0.22-0.79 mm
0.009-0.031 in
Dots face up. Ring gaps should be .015 / .025 / .015
Old Aug 24, 2009 | 10:09 AM
Thanks for the help... I did a quick check on cylinder #5 and 1st ring= .018 and 2nd ring= .027 ....How tight should my gauges be in the gap? As tight as possible while keeping the rings squared correct?
Old Aug 24, 2009 | 10:27 AM
racer7088's Avatar
Yes as long as you don't force them in and it sounds like you are good.
Old Aug 24, 2009 | 11:11 AM
Here's a pic of cylinder #7 and #6...#7 is worse than #6...The bore taper on #7 right now is .005 ....I'm going to hone it some more...The pictures make it look worse than what it is in real life....You can't feel any of it with your finger tip..Also thanks for not bashing and actually helping...
The thinnest gauge I have is .0015 and if I tightly put across a flat surface I can definitely feel it and catch my fingernail on it...So the markings are less than .0015 deep....
Attached Thumbnails Cylinder Honing-img_4024.jpg   Cylinder Honing-img_4026.jpg
Old Aug 24, 2009 | 01:12 PM
racer7088's Avatar
Arrow
I think it will run for sure but probably just won't be perfect. It doesn't look too bad from here though at least.
Old Aug 24, 2009 | 01:23 PM
The other cylinders look perfect...What I'm afraid of is the rings not sealing properly in #6 and #7 ...Or breakage...Will it make more noise with those areas being the way they are?
Old Aug 24, 2009 | 03:18 PM
racer7088's Avatar
I doubt you will have any noise but the rings may wear out faster on these bores as time goies on.
I only know that it won't "help" the rings to be on this finish but they still might cope better than expected.
Old Aug 24, 2009 | 08:16 PM
Once again I'll take some more pics tomorrow..It looks a lil better now...I started to clean the block with some soapy water and got some "flash" type rust on the cylinder walls now and it won't wipe off with mineral spirits and rag..WTF?!?!
Old Aug 24, 2009 | 09:00 PM
racer7088's Avatar
yes when you clean a cylinder that happens unless you use anti rust or WD40 right away.
