Advanced Engineering Tech For the more hardcore LS1TECH residents
Wipe pattern on TFS 235's and Harland Sharp
Old Feb 16, 2014 | 10:42 PM
ice95z's Avatar
Default Wipe pattern on TFS 235's and Harland Sharp
Bought a set of TFS 235's by TEA a few months ago. Have not installed them yet but trying to get a rough estimate of what exactly is going to change when they are milled. 70 to 62cc
I know the pushrod length will shorten and I have that figured out but the HS Rockers are shimmed.
Will milling the heads have any effect on the wipe pattern of the rocker arm If I change the pushrod length properly for the milling of the heads?
The rocker arm sitting on the shims is a fixed pivot point on the head. Is the only change to the geometry going to be the pushrod length? If im making up the difference in the milling with the proper pushrod length, nothing else should change correct?
Too much math, Im probably over thinking this and I know the only way is to measure for sure but with no checker springs, or solid lifters to be completely sure i figured id pick someones brain in the meantime
