Latest and Greatest Proper Engine Break in Procedure |
Smart move, ddnspider! Good procedure for break-in! |
Originally Posted by G Atsma
(Post 19851649)
I'm just commending you for making it a separate post. Lance put it up, I know. |
(Post 19851752)
I know his business is in Santa Ana, California, and he's a sponsor here. Other than that.... |
ATK Break In Procedure: http://static.summitracing.com/globa...break%20in.pdf Livernois Break In Procedure: http://livernoismotorsports.com/imag...ak_In_2015.pdf AERA Break In Procedure: https://gafiero.akroncdnr.com/docs/BreakIn.pdf Hastings Break In Procedure: https://www.hastingsmfg.com/ServiceT..._procedure.htm |
FWIW, I don't really do anything weird when I break in an engine, like what Lance posted. I've never seen anyone break in an engine like that and I don't understand why anyone would. I don't think the rings get very hot at idle (no load) so I can't agree with doing it to keep the rings cool so they don't lose their temper. If the engine is broken in on an engine dyno, it's usually run with no load until it reaches temp. Then it goes through a cycle where the load and RPM is varied and repeated with increasing load and RPM. I think some of the software for the Superflow engine dynos have this program available which does this automatically. The engine is usually broken in within an hour. If the engine is broken in in the car, I will try to emulate the engine dyno procedure. I let the engine get hot at idle speed while I check for leaks or other issues. Then I'll drive it around with light load or low throttle input and keep the RPM low as well. I'll start gradually putting more load on it and increasing RPM while keeping an eye on the temp and oil pressure, but I don't do any WOT pulls. That will be done on the dyno. |
Originally Posted by KCS
(Post 19853484)
Engine Start Method HI ALL, the quotes, I found FUNNY as they referred to an engine with carburetors, flat tappets, etc. The referenced method is similar as I state though they use different terms. SOME ARE Different from my method and may be true WHEN a CAST IRON ring is fitted. This too is found in Cosworth Tech, the cast ring method. Many engines are fitted with a Ductile Iron, moly filled top rings. I too agree with the OLD SCHOOL method, to a lower extent. Then the question about "engine manufactures" NON are above referenced, they are engine assemblers ! NEXT my method is Mis-Quoted by spider, NEVER did I state to Idle the engine at startup. I STATE to follow the prelube tech, with warm oil if possible AND a warm block if possible they bring the engine to 2000+ RPM for short periods of time, stop the engine allowing ring cooling time, then repeat doubling those periods. I would add that the ability to increase the engine load at each interval is agreed. I believe THIS quest is proper/valid DUE TO CHANGES in piston design AND ring material away from engines created OVER 100 years AGO ! Lance |
Originally Posted by Pantera EFI
(Post 19853583)
Then the question about "engine manufactures" NON are above referenced, they are engine assemblers ! Is there any sources you can post from an "engine manufacturer?" I think that is the point of this thread.
(Post 19853583)
NEXT my method is Mis-Quoted by spider, NEVER did I state to Idle the engine at startup. However, now that this miscommunication has been cleared up, it seems the procedure you recommend does not vary much from the accepted procedures stated in the links I posted. |
(Post 19853620)
You misquote Spider. He didn't say that, I did. When Darth stated he only started the car up for a few seconds, obviously without putting load on the engine, you said that to ""start" for a few seconds is BEST." He again commented that he followed the procedure you stated, specifying idle only, to which you did not correct him. That gives the reader the impression that idle speed and no load is required for your break in procedure. However, now that this miscommunication has been cleared up, it seems the procedure you recommend does not vary much from the accepted procedures stated in the links I posted. "Your reported "start" for a few seconds is BEST. THE OLD STORY, to run a new engine, new rings, for 20 minutes at 2500RPM is the WORST POSSIBLE method. The method that is used by engine professionals is to start (run) for 5 seconds/stop for 10 seconds/run for 10 seconds/let cool for 20 seconds, etc. The time periods are thus doubled each run/stop sequence. This will keep the rings cool keeping their temper. There have been many pictures posted her showing BAD cylinder walls caused by metal transfer with improper engine run in procedure. Lance" To: "I STATE to follow the prelube tech, with warm oil if possible AND a warm block if possible they bring the engine to 2000+ RPM for short periods of time, stop the engine allowing ring cooling time, then repeat doubling those periods. I would add that the ability to increase the engine load at each interval is agreed. " |
I'd like to get more into the reasons why we do the things we do for the break in procedure, and maybe start a conversation about how to do it better. The links provide some guidance as to what we are trying to achieve during the break in; which is mainly all about seating the rings. To do this, the engine must see load so that the ring faces are forced into the cylinder wall from the combustion pressure and wear into eachother. So how do we load the engine, and how do we increase that load throughout the process? Throttle input? Gear selection? The engine must also reach operating temperature so that the engine is not damaged during the high loading cycles. Is a 180 degree thermostat a good idea to use, or should a standard thermostat be used for the process? Last but not least, the oil must also be able to provide adequate lubrication and cooling, as well as wash away the microscopic particles broken off from the cylinder as the rings wear in. One article suggests decelerating in gear so as to create a high vacuum in the cylinder to encourage oiling the cylinder walls and rings. Would a lower viscosity oil be beneficial to "wash" the cylinders better? Would overfilling the pan 1 or 2 quarts be a good idea? I'm glad this has come up. I should be firing up a fresh engine soon so it's a good time for me to explore this a little more and maybe revise my break in procedure. |
I'm in the same boat...rebuilding an ls6 right now. Got a build thread going in the gen 3 internal section. I figured I'd fire it up and let it idle to operating temp to make sure no leaks etc. Let it cool. Come back later and drive it and start varying throttle and dial in the AFR...then wot pulls. Until Lance posted that up and threw me off lol. I am a strong believer in running an LS at 190 degrees or less. Kept some rather high hp pump gas street cars alive that way even though people claim they're fine at 210. I also am a pretty strong believer in the Shell conventional Rotella. I don't get into the synthetic stuff and believe in more frequent oil changes in general. A secondary reason for changing the oil other than the oil breaking over time, is that it also cleans and removes junk from the motor. When you change it more frequently you remove debris and impurities more frequently. Also becoming a big believer in running more than 5.5 quarts and leaning more towards 6.5 or 7. Seeing alot of high hp street guys logging oil pressure with accurate resolution now and hard qcceleration is dropping the fuel pressure significantly even if only momentarily. |
(Post 19853754)
(Post 19853774)
It's funny you mention this; a buddy just showed me an Engine Masters episode where they tested different oil levels in a BBC. They overfilled a stock pan and an aftermarket pan, and then drained a quart at a time between tests. As they reduced the oil in the pan, they gained power and stabilized a dip in the oil pressure at higher RPM. I think they gained a solid 20hp after all was said and done. It was a solid roller too, so had it been a hydraulic, they probably would have gained more power. |
(Post 19853799)
Was it overfilled to the point of whipping around the crank? If so it would make sense. How less oil fixes an oil pressure drop doesn't compute lol....but if it was again whipping around the crank I suppose that makes sense. Too many other people have logged data and g force during a pull and showed the drop in pressure that was aided by overfilling the pan. This is more real world as opposed to an engine Dyno. Either way it's cool to see changes like that. I always get a kick out dialing in a tune and feeling how the car picks up power and even the pitch of the motor changes tone. I have a pretty long stroke, so to address this I went with a Moroso 7qt pan and a remote filter, however, I don't plan to fill the pan to capacity. Just how ever much oil the engine needs to sustain pressure and keep the windage to a minimum. I hope it's worth something because plumbing the oil lines was a real PITA! |
(Post 19853815)
Yeah, that's the assumption, hp losses and oil pressure issues were from windage and oil aeration, yet they weren't simulating the g forces from accelerating either. It was a good experiment to get the brain working. I have a pretty long stroke, so to address this I went with a Moroso 7qt pan and a remote filter, however, I don't plan to fill the pan to capacity. Just how ever much oil the engine needs to sustain pressure and keep the windage to a minimum. I hope it's worth something because plumbing the oil lines was a real PITA! Where are all these minds about engine break in lol?? |
(Post 19853820)
Nice....just make sure you don't use the slow analog gauge as confirmation you aren't dropping pressure at WOT. Where are all these minds about engine break in lol?? |
(Post 19853842)
Hiding in the wood work, my friend..... lol |
© 2024 MH Sub I, LLC dba Internet Brands
