Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Advanced Engineering Tech
Reload this Page >
Is there a reason NOT to use 317 heads with correct pistons to achieve 11 to 1 comp
Notices
Advanced Engineering Tech For the more hardcore LS1TECH residents
Old 08-04-2018, 10:07 AM
trik396's Avatar
Default Is there a reason NOT to use 317 heads with correct pistons to achieve 11 to 1 comp
Every one says 317 heads are junk and maybe I am missing something. With the proper piston cc volume you can obtain any compression deemed necessary for your application.
I want around 11 to 11.4 to 1 compression for a street 370
many companies offer full port and polish for 317 heads.
why shouldn't I do this if I have the heads already ?
this would be with the best flowing intake and headers available
And of course a good cam possibly from BTR.
any opinions appreciated
trik396 is offline
Old 08-04-2018, 10:10 AM
Just speculating, but it might require too much of a dome which could interfere with good flame propagation, and might cause PTV issues as well.
G Atsma is offline
Old 08-04-2018, 10:13 AM
trik396's Avatar
Very good points. Thanks
trik396 is offline
Old 08-04-2018, 09:08 PM
Moderator
I’ve seen quite a few guys get the chambers welded to achieve better compression numbers from the 317 heads. They are basically a 243/799 head with a bigger chamber. I believe that AI (Advanced Induction) offers a CNC port, along with a welded chamber service.
Che70velle is offline
Old 08-06-2018, 06:52 PM
trik396's Avatar
I am so torn as to what to do here. Money is an issue so spending the cash to get say 799 heads and have them worked on would be considerably more than working with the 317s I have. I can get around 10.5 to 1 easily with the large chamber 317s with proper piston zero deck and head gasket. The quandary is whether spending the extra cash on different heads is worth the maybe 20 to 30hp that I would gain.
I have a somewhat flexible amount of money to spend but I also have to get the 4l80 worked on plus a convertor and a rearend eventually.
These decisions are killing me!
trik396 is offline
Old 08-08-2018, 07:53 AM
Restricted User
862/706 heads offer roughly 1 point of compression over 317s.
A little hand porting, even with a die grinder and a flapper disc will make them outperform 317s in almost every way. Don't stress too much over the valve size.
JoeNova is offline
Old 08-08-2018, 10:59 AM
cam
You could replace the heads a lot cheaper than new pistons. Get the 799 and go you wont regret it, heads are where your focus and money should be spent first and foremost. 799/243 with shelf grind on a 6.0L is a thrilling combo with supporting bolts ons; long tubes, new style truck intake or LS6 400rwhp with ease. Run the stock 6.0 pistons and short block will work fine.
cam is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
