Header Modifiaction to Reduce "Choke"
Has anyone heard of this? He said he's done it for quite a few customers and all of them loved the improvement. Just curious. Thanks!
http://www.ls1miata.net/gallery/miat...ust_008?full=1
http://www.ls1miata.net/gallery/miata/header_004
Now, you can do a 4-2-1 you simply need to have you tubes placed properly to do so. You can even do a 4-2-1 with a few mandrel u-bends if you know what you are doing.
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
EVO is Exhaust Valve Opening
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice. For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used. I tend toward using the Peak HP, other wise the headers get REALLY long primaries.
So, on a 346 you'll find ~32" primary for most applications.
Now, that doesn't take into account in an engine when you have a poor exhaust port, or a really good port. As an example. on an LS7 good results have been shown with a 1 3/4 header. This may be due to the fact that the exhaust port is relatively poor in comparison to the intake side, and the velocity of the 1 3/4 over a 1 7/8 does a better job. Time will tell.
So, these formulas give you a good number to start with, but some empirical testing is always in order.
