LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Advanced Engineering Tech (https://ls1tech.com/forums/advanced-engineering-tech-107/)
-   -   Warped Heads - What's Acceptable (https://ls1tech.com/forums/advanced-engineering-tech/531825-warped-heads-whats-acceptable.html)
Builder Jun 26, 2006 10:54 AM
This question is about an SBC. But, since this is more of a general engine technical question, I thought it would be appropriate to post it here, too.
Adrenaline_Z Jun 26, 2006 11:11 AM
That number will change depending on the head gasket type you end up using.
If I recall, steel gaskets recommed not more than 0.006" variance. I would
think that value accounts for both mating surfaces (head and block).
Just out of interest, I measured my block to <0.002" and heads were 0.002" -0.003".
Builder Jun 26, 2006 11:43 AM
Thanks, that's good info...
ezrollin Jun 27, 2006 12:02 AM
arent you supposed to measure it with a precision ruler and feeler gauge?
FattyMcTrickle Jun 27, 2006 03:09 AM
Yea that or one of those real expensive flat block things and a feeler gauge.
ezrollin Jun 27, 2006 05:56 AM
I was thinking of trying plate glass. I bought a steel ruler, but it is insufficient(its not precision).
© 2026 MH Sub I, LLC dba Internet Brands
