Cams and supercharger
Did I ever say that scavenging doesn't work on a supercharged engine? Actually, the whole point of my post is that it is easy to overscavenge a supercharged engine.
Mike
Mike
A test was done some time back to compare superchargers and turbochargers. An engine made 8XX hp on a supercharger, then made 950 hp on a turbocharger, then made 1000 hp on pre-compressed air, all at the same boost level. So, let's just assume that this engine was running 20 psi boost. That means that the turbocharged version had 20 - 40 psi backpressure, but it reduced power by only 5%. I know if you add 20 - 40 psi backpressure to any naturally aspirated engine, power will drop by way more than 5%. A while back, I reduce backpressure from 9 psi down to 6 on a NA engine and gained 13% power. My point is that perhaps the added backpressure from the turbocharger prevented overscavenging (good), but increased pumping losses (bad) for a net loss of only 5%.
I really wish someone would run a once-and-for-all camshaft overlap test on both turbo and supercharged engines. It would be really great to see every thing else stay the same, but just altar overlap and see the results. The cams could be something like:
test 1: 240/250-106
test 2: 232/242-110
test 3: 224/234-114
Mike
Mike
Also if you can give me ANY idea of the difference in pressures of a cylinder, exhaust port and intake port during overlap of a supercharged vehicle you might undestand this. If you have seen anything work better back to back with high overlap vs. low overlap on a supercharged vehicle you might understand this, problem is you haven't and so you will continue to listen and live by logic that doesn't work. The only way you OVERscavenge a motor is when you have too much overlap for it, problem is you haven't SEEN too much before on a centrifigal blower motor and have PROVEN that is the exact problem. If you do run into this then you have another issue in the system that's holding it back, not the camshaft overlap.
Hell even you understand boost to backpressure ratios in turbos, all you have to do is extrapolate on that some more.
Well enough out of me, I'd rather do other things than share what I know about this if I have to argue these points.
Bret
Thanks
what is much more important is timing... thats what everything is debated about above.
one of the basic concepts of a performance camshafts involves opening the exhaust while the intake valve is still closing.... this period while both intake and exhaust valves are open is the overlap...
the concept they're arguing about above, is how much (if any) overlap is ok for a supercharged motor... some argue that with both valves open, the incoming pressurized air will go right out the exhaust.
others argue that it works the same as a NA motor, and it doesnt matter, nothing weird happens..
and most of the smart ones are in between those two extremes... although there are alot of people who think any overlap is a "bad" thing on a boosted motor.
its one of those things where 100 people can do their own testing 100 times, and every one of them will draw their own conclusion..
but to sum up your original question.... the LIFT itself is not effected by the supercharger... but the overlap (and therefore the duration and LSA if you're going by basic cam specs) can be... so you most likely dont want a "huge cam"
Peace all.
First, who do you think you are being reasonable on this board?
Second, you have the above backwards and probably know that but I didn't want anyone to get confused.
(and i mean that in a good way)
not been mentioned in this discussion:
- LSA does not determine overlap alone
- Overlap at the lobe, is not equal overlap at the valve (pre-load, rocker ratio, floating...)
- Compression can't begin until both valves are closed. Cylinder pressure
is determined by IVC, and VE (< all that encompasses cylinder filling).
- Overlap is tuned to work within a small range of RPM. You can't grind a
a camshaft to equal efficiency over the entire operating range...especially
in a non-variable environment.
In a race motor, does it really matter if some of the charge is wasted outside
of the tuned area?
oopsie... you're right.
it should say:
...opening the intake while the exhaust valve is still closing..
not the other way around.. good catch.
Mike, i'm not giving out the data for free... sorry.
Bret
Can you at least share what you think is not enough, just right, or too much overlap? At this point, no one has even defined the amount of overlap we're talking about. Who knows, maybe we all agree in the end. . .
Mike
Who in their right mind would give out that kind of information for free? Especially the kind that cost THEM time, effort and $$$$ to gather?
Seriously, search through their posts and pick up on the crumbs and start doing research. You'll learn A LOT, you won't become an expert but at least you'll gain an appreciaton for this stuff.
Mike
BOSS APPROVED!
