Vizard's LSA - CI/Inch Valve Diameter chart
No matter what you do to a carburator it'll never be anything beyond a gas can with a straw sticking out of it period.
You can add a ton of air bleeding and emulsifiying orifices and circuts you can redesign the discharge orifices all day but its doesn't change that fact ever. A carberator is a pressure differential device. No pressure difference no function. Sure a carb can tolerate low idle vacum becuase the venturi it self genrates Some of the signal. but as soon as that fuel hits the plenum it falls right out of suspension.
we have a huge difference between a Electronics guy and someone who does what he talks about for a living. Honestly the EFI system is not holding the EFI pro-mod back. Something else in the system is.Could be the ratting for flow on the TB's honestly. You have one TB with a rating at 1.5 inchs of mercury and another at 28inch of water deprssion. You also have a laminar flow elemnt in the carberator which is the venturi itself the helps drive airflow through the plate.
but I am done with this topic. EFI wins if carbs are so great why is proof is in the pudding. F1 runs EFI. if a carb had an advatage I think the companies spending millions daily to find HP would be all over it.
If you want to talk fankly about fuel atomoization differences between carberators and EFI glad to have that discussion.
But peak power is only a number.
Id rather have a very wide spread of power, than a simple big number over a narrow rpm band.
If high numbers were all that mattered...maybe we would all run big 2 stroke engines, that make no low end power or torque, but very impressive numbers at the top end.
A carb can maintain good AFR's etc over a limited range of operating conditions, whereas EFI can maintain optimium AFR's under ALL conditions. So generally speaking, in most cases, it will offer better performance.
I have a few questions based more on the original topic.
Say you have 2 cams specs first one being a popular cam:
Cam 1 (108 icl / 110l lsa)
Intake
.006 - .050 - .200
294 -- 243 -- 164
Exhaust
.006 - .050 - .200
300 -- 250 -- 169
IVO .006 - .050 - .200
------ 39* - 13.5* - (-26) --- BTDC
IVC .006 - .050 - .200
------ 75 --- 49.5 ---10 ----- ABDC
EVO .006 - .050 - .200
------ 82 ----57 ----- 12 ----- BBDC
EVC .006 - .050 - .200
------ 38 ----13 -- (-32) ----- ATDC
26.5* overlap
11.03 SCR - 8.02 DCR
Cam 2 (106icl 108lsa)
Intake
.006 - .050 - .200
286 -- 236 -- 159
Exhaust
.006 - .050 - .200
286 -- 236 -- 159
------ 37 -- 12* - (-26.5) --- BTDC
------ 69 --- 44 ---5.5 ----- ABDC
------ 73 ----48 ----- 9.5 -- BBDC
----- 33 ----- 8 --- (-30.5) - ATDC
20* overlap
11.03 SCR - 8.47 DCR
Wouldn't cam #2
Have less chance of reversion?
Make more bottom end TQ?
Carry TQ/RPM just about as far as cam 1?
Be "easier" to tune?
Bottom line is a person with a high knowledge base on carbs can and will outperform the EFI guy. Argue all you want, show me proof that EFI will outperform it in a series as tight as NASCAR or Pro Stock.
Intake
.006 - .050 - .200
294 -- 243 -- 164
Exhaust
.006 - .050 - .200
300 -- 250 -- 169
26.5* overlap
Intake
.006 - .050 - .200
286 -- 236 -- 159
Exhaust
.006 - .050 - .200
286 -- 236 -- 159
20* overlap
Wouldn't cam #2
Yeah. And the ability to breathe can be influenced, both positively, and negatively by valve events/overlap.
Not really sure what you mean there. Overlap is ONLY defined as degrees of rotation over which both valves are open. So, thats another DUH statement.
Virtually all of the components and specs you've regarded as meaningless, all have an effect on what cam specs will work best.
Anway, I found David Vizard's article called Perfect Timing he wrote specifically for GMHTP in Oct-03. It's a 6 page article geared toward Gen III engines. I also found another article he wrote called Setting the Record straight: Exploding Valvetrain Myths. Both are good articles about camshafts with good images to reinforce his points.
First of all these cams aren't even in the same league. Can't even compare them.
You are comparing a T-Rex size cam to like a TSP torquer.
Look at the IVC and EVO of both cams it is pretty obvious that cam2 will come on sooner in the rpms, peak sooner, peak trq sooner.
So basically minor bolt on, stock gears the cam2 would whoop the others *** in quarter and it wouldn't even be funny.
But if you optimize the combo of both, then you are comparing a midget Asian elephant to a mamoth.
