Heads...intake Vs Ex ratio's ??
I am considering new heads for my Procharged 408. As usual the "search" function comes up with dozens of threads bordering on civil war as to who make the best product....
Using Brian Tooley's "under the curve" formula has brought some enlightenment....thanks.
seems everyone is focused on the intake side of the flow charts. I am of the opinion, that what ever goes in has to go out somehow?? especially in an FI situation.
So here is the question, is there an optimum Intake Vs. Exhaust ratio? I realize that it will be different for an NA vs FI application, but would really like to see some engineering data on this.
Assuming I am supposed to leave specific brands out of this thread, I will be vaugue.
I was planning on utlizing a certain head that would allow for the better flowing Gen IV OEM intake manifold. Then I find out that the exhaust flow is no better than the "budget" heads I currently have. On the surface it seems pointless to spend big $$ for better intake numbers, only to hit a roadblock before I even hit the header???
OK, I'll buy into both of those statements.
Are you goin' to tell (some) of us who don't buy into that why it is?
I'm guessing that flow at higher lifts is way more important than flow at lower lifts which makes AUTFC invalid. Am I close?
It always amazes me how much bad information becomes Gospel to so many people. One little part of me says that perhaps that is a conspiracy among those who really know what works and want to keep the good information from the masses.
That's not true, because the folks who I deal with who know what works and make money building engines/parts that work (read that as "make power") actually feel sorry for the folks who believe the BS, but if they tell the truth they are mocked or put down for going against the Gospel. After a while they give up trying, and just make money helping folks go fast.
Sad state of affairs, ain't it?
"Who do your trust?"--The Joker
i know of several other experts that don't subscribe to this theory also,and they don't post up on this board,at least not very often..
does anybody else have an opinion,or different theory they would like to discuss?
My take is that if your intake port makes lots of power (not flowbench numbers) your exhaust port has to get the residual products of combustion out efficiently. Because the delta p in the exhaust is huge compared to the intake, each exhaust port needs to be tailored to match the power the intake port allows to be made. I can't imagine coming up with one intake/exhaust flow ratio when tested steady-state on a flowbench that would be valid for many head/port configurations on a running engine.
So let's work on getting more air into the running engine and then doing the exhaust port well enough to let it out. That leads to large intake/exhaust valve diameter ratios like 2.2/1.6, but not necssarily intake/exhaust flow ratios from a flowbench. LS7/L92 look familiar here?
Anyway that's my take on it. Jess or others may have a different take.
and just to show more of my lack of knowledge to the tech world,what the hell is delta p?
its about "where" you want the torque peak(bmep), its about emissions, its about BSFC, its about countless other factors.
Delta P is very important (Pressure at location 1 minus pressure at location 2) because without differential pressure, there will be no FLOW.
all we need is an in cylinder pressure plot to get the full picture.. it makes so many things considered "black art" much easier to grasp.
the question is, how much energy to pump exhaust are you willing to give up to ensure excllent cylinder filling
Yeah, delta p is just the difference in pressure. It is why we have wind in our climate. Air flows from those big Hs in the weather map toward the big Ls. Same thing in an engine.
I suggest that good engine designers take into account those varying pressures inside the operating engine when they create port shapes, design intake and exhaust manifolds and specify valve events.
As far as exhaust pumping losses, I would continue to favor the intake until I lost power. Of course determining where that point is what separates the winners form the also-rans. Anyone making his/her living from this knowledge or ability to determine same isn't about to tell. They may sell you parts, however.
Jon
FWIW, the Greek letter Delta (Ä) is often used in math to mean a difference. The p is often used for pressure.
Good question, deuce!
Jon
But to think there is a certain percentage that is the best is just wrong. Different applications will want different results. The very idea that you may would want to limit one or the other to reach an certain percentage is just goofy. Get as much as you can out of both sides and design the cam to accomodate the head.
Basically, we are saying that flow RATIOS are BS, GM has proven this.
Here is my basic comment for NA engines..
-You only have a maximum of 14.7psi/101.325 kPa pushing the air into your cylinder (best case)
-But you can have sigificantly more pressure pushing the air out of the cylinder
If you ever get a chance, look at the difference in porting between intake and exhaust ports on high-end heads that make high-end power. What works in an exhaust port doesn't necessarily work in an intake. That's more important than the flow ratio at 28 in. H2O.
Jon
