Projector headlights...yes or no. I have a good reason why I ask
OK guys here's the deal. Previous owner apparently hit a deer in my Camaro. I have replaced the broken fender on the car now, the bumper still has a crack in it but it isn't awful, I need to look into seeing if I can repair it or not. The bigger problem is when the old headlight bracket bent it broke the mounts on the driver side headlight. The only thing holding it on is the single bolt on the top. Needless to say it is a pain to aim, and if I lean over the car to check my oil or something and bump it too hard it shifts and I have to aim it all over again. Plus, the lens is hazing up some (not awful but it isn't as clear as the passenger).
Some of you know of the dual halo projector headlights on ebay. I believe the Guz has them. I can get a set of black dual halo projectors, plus front and rear black corners, for approximately $140-$160. I've always kinda liked those headlights, once the LEDs along the side are disabled, plus they are HID ready. Should I do it? My car isn't a show car or anything like that.
Pic of my car as it sits now:
Here is a pic of someone's car on this board with the headlights I'm considering:
https://ls1tech.com/forums/showthrea...ghlight=reject
im having the same problem... cant find a projector housing that i like to go with my HID's. Best ive found so far are the halo ones in clear, not a fan of the dark ricey lookin color imo, obviously with the ugly halo dissabled.
If you like them, get them! A lot of guys (including myself) run some version of Halos and like them a lot. At the end of the day you are the one driving your car and looking at it and you gotta make yourself happy first and foremost.
Foglight projectors? Hmm.. Thinking of maybe getting them, and modifying the cutoff to work better. From the pics it looks like the projector is held in by 3 or 4 screws on the back of the headlight. If I did, I could do a writeup on it.
Keep the opinions and thoughts coming guys, I'm still kicking it around.
