Roll cage AND subframe connectors?
!Dial-up Director
When I get the roll cage in will subframe connectors still be needed? Will the cage act as a "subframe" connector itself?
Justin
Justin
Re: Roll cage AND subframe connectors?
depending on your cage and SFC sometimes they will weld at the same points making everything even stiffer! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
either way i would still have both. The stiffer the body is the better and they will not counter act each other. My $.02 <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I can shift faster than you.
Justin, get the Wolfe SFCs ($120 and 10lbs) and the Wolfe cage. This is what I might be doing (already have the SFCs on the car).
Also, if you get the cage, spend the extra money on the removeable door bars. Money well spent. Joe Kizzire's Wolfe cage looked great.
