Scratches in Stainless Muffler - Motorcycle
I laid my bike down and put some scratches on the muffler. What do you guys recommend to reduce the look of them? The only real rough spot is the end where it meets the mid pipe. Thanks!
![](http://i20.photobucket.com/albums/b216/105/crash001.jpg)
im in the middle of polishing my borla and im using this >http://www.svtperformance.com/forums...r-exhaust.html as a guide. I couldn't find a flapper wheel so its all by hand, for scratches like that tho I think you'll def want a flapper wheel.
I've wondered if this could be done so I'm kinda curious too. I know any of my friends that this happened to just bought a new slip-on, especially if it was just the stock pipe that got scratched. If you have a stock pipe and wanted to keep it that way, you could also check some sportbike forums out. I know some people will almost give away their stock pipes if they replace it with aftermarket. Might be cheaper if you have to buy all of the equipment to fix the scratches.
I'll keep an eye on this either way. My yoshi pipe has a couple of small scratches (not from going down) so if there's something I could do to get it back to a nice finish, I might be up for trying it.
I think if I got someone elses stocker it would have to be welded on wouldnt it?
I'm pretty sure you can get most of that out using hte method on SVTP. Just keep stepping up with the sandpaper. Could probalby even do it by hand since it's pretty small. I've polished up a few things and it's not really that hard.
