"FLEX Foursome" buffer kit now available We have assembled a powerful kit to attack a wide range of surface scratches and other blemishes. Starting with the FLEX 3401 polisher, it provides the necessary power to see fast, visible surface improvement for the beginner or detailer. http://www.tropi-care.com/FLEX_Orbit...3401%20vrg.htm The Menzerna Super Intensive Polish is becoming more and more popular for us as a fast improvement product including use on harder clear coat surafces. http://www.tropi-care.com/Menzerna_S..._p/men-sip.htm The new purple "KOMPRESSOR" pads have arrived. They feature a stronger cutting ability than even the yellow pad. This new hybrid compounding pad removes oxidation, heavy swirls and most scratches. The slotted pad face of both of these pads adjust to the changing surface contours to provide greater surface contact, more consistent results and less product splatter. http://www.tropi-care.com/Purple_KOM..._p/tcp-k00.htm For lighter scratches and surface refining after the purple or LC orange CCS foam pad, this pad can be used to smooth and refine the surface using lighter polishes. It also removes very light imperfections, mild swirling and light oxidation. http://www.tropi-care.com/White_KOMP..._p/tcp-k03.htm List price for this group is $364.36. Buy it online at www.tropi-care.com for $327.92 with promo code"10offTC" (a $36.44 savings) Bonus pricing on phone orders. Contact me toll free at (866)341-0050 for more details. |
whats the advantage to this over the porter cable model you sell? |
Originally Posted by ChevyChad
(Post 11267197)
whats the advantage to this over the porter cable model you sell? http://www.youtube.com/watch?v=Yht1uHJLNlQ While I havent used a PC, I had never before owned a buffer/polisher and stepped right into the Flex w/o incident. There are pros/cons for both. The PC will accept 4" pads which makes getting into tighter spaces easier. The smaller pads will also yield more correction than the 5.5"-6" on the PC. The Flex only has one backing plate size that fits 6" pads. You can finish a vehicle in less time because of the increased surface area you will be able to cover but cant quite get to the tighter spots. |
My2kTA is right on with his assessment of the 2 machines. Lake Country is looking at other backing plate sizes for the FLEX for future consideration. The FLEX has a smoother, tighter rotation compared to the PC. It also has a progressive trigger to control your speed at the higher end. The PC is a great machine for both the beginner or novice. It's user friendly and the key is to have patience during its use to remove deeper, stubborn scratches or blemishes. Feel free to contact me for more info or any questions. |
Steve, Will the kompressor pad work with the pc? |
Originally Posted by mrhzk35404
(Post 11270522)
Sweet, just in time to start restocking cleaning supplies before G13 |
Free press for Steve and Tropicare! Customer service and product quality are both top of the line. If you love your car, get a buffer and some products from TC. Just bought my second CTS-V, with a 414ci LS3. New TC refills arrive today. Pics will follow |
Originally Posted by 99zee
(Post 11271431)
Yes, the kompressor pads fit both the PC and the Flex. I have used the LCK pads with both machines. The backside pocket of the pad is right at 5-3/8". The FLEX backing plate measured at 5-1/2" and the LC backing plate is right at 5-7/8". Tighter fit with the PC but it will work fine. |
My flex foursome just showed up here at work a few minutes ago and to be honest its 70 degrees here in Denver today and im really thinking about getting the hell out of here and going home and testing it out:D Thanks again Steve@Tropi-care for the products and such fast shipping!! |
i am not very good at this picture stuff but just wanted to show the great work that the sip and flex can do. i have the porter cable buffer but the flex is far better than the pc. there was blemishes that the pc could not remove and the flex was able to take care of that. great product. thanks stevehttp://i287.photobucket.com/albums/l...8/DSCN1177.jpg |
http://i287.photobucket.com/albums/l...8/DSCN1178.jpgused it on the camaro while i was at it |
BUMP...everyone needs to own this combo. |
April 17 Update This kit has been very popular for us as evidenced by a number of fellow forum members have taken advantage of this opportunity. The combo of the FLEX and Menzerna SIP provides a very formidable attack many surface scratches and other blemishes. It is particular successful for use on harder clear coats such as C5, C6 and others featuring scratch resistant PPG Ceramiclear surfaces. If you are anxious for results as a enthusiast or detailer, looking for/need more response than what a PC can offer, I suggest taking a closer look at this kit. |
© 2024 MH Sub I, LLC dba Internet Brands
