how to remove seats for cage install? i searched this for about a hour and i might have missed it, but i thought i should atleast ask just incase i still can't find it. i'm installing a 4 point cage this weekend in my camaro, what size bolts hold the seats in and the plastic Interior stuff in. i ask because my car isn't at my house it's about 30-40 minutes away and with work and school this is the first time i will have two days off in a row without school or work so i can atleast remove the interior so the cage can be welded in. is there a trick to removing everything or something i should watch out for on the inside. like should i just remove the seats and roll the carpet up to the console or should i remove the console? i know, why am i wasting my time with a 4 point, it's because i dont know what the cars' going to run so i thought it would be a good cage to start with if i need to add on i can. |
i came up with this for you.. you need a T30 Torx and a 13mm socket and ratchet. i had to go buy a T30 socket for my ratchet because i didnt have one. the T30's are for the 4 bolts on the back of the top of the back seat that hold the seat belt on there. everything else is 13mm. the 4 bolts holding each front seat in, 1 13mm bolt per rear lower seat (on the front of them) and 1 13mm bolts holding the upper back seat in place (getting a ratchet in this area was a bit tricky) i'd take out the front seats first, then the lower rear seats then the upper rear seat, although i took out my lower rear seats while waiting for instuctions on how to remove the electrical connection, i had already removed all the bolts for the front seats. the lower rear is cake. that one bolt and then you just pull them out |
what he said ^ the seats are held down by four 13 mm nuts two in front two in the rear and there are electrical connections under each seat, then they just come right out. the seatbelts i do not believe have to come out though for the cage install. |
Thank You; Torchd 02 TA and DevilDougWS6, for the help. how hard is it to pull the carpet up? |
once you have the seats, seatbelts, center console, and all the plastics out, the carpet just pulls right up with a little finesse. so you really DO have to remove the entire interior to install the cage. |
Originally Posted by DevilDougWS6
(Post 11281966)
this is the first time i have taken the interior out of a car, could i leave the center console in and just role the carpet up and lay it over the console? the plastic pieces are screwed in right, the ones in the back hatch and on the back seat walls? |
Originally Posted by rob scott
(Post 11282448)
the ones in the back hatch area, and the ones on each pasenger side rear seat area where the rear spearkers are. im sorry to keep bugging you guys but this should be the last one what holds the shift knob on a auto? and the bolts in the console are 10mm right? |
(Post 11282517)
the ones in the back hatch area, and the ones on each pasenger side rear seat area where the rear spearkers are. im sorry to keep bugging you guys but this should be the last one what holds the shift knob on a auto? and the bolts in the console are 10mm right? I have an M6 car so i have no idea how you take the shifter knob off for an auto sorry. and yes the bolts are 10mm |
Originally Posted by TORCHD 02 TA
(Post 11281329)
i came up with this for you.. you need a T30 Torx and a 13mm socket and ratchet. i had to go buy a T30 socket for my ratchet because i didnt have one. the T30's are for the 4 bolts on the back of the top of the back seat that hold the seat belt on there. everything else is 13mm. the 4 bolts holding each front seat in, 1 13mm bolt per rear lower seat (on the front of them) and 1 13mm bolts holding the upper back seat in place (getting a ratchet in this area was a bit tricky) i'd take out the front seats first, then the lower rear seats then the upper rear seat, although i took out my lower rear seats while waiting for instuctions on how to remove the electrical connection, i had already removed all the bolts for the front seats. the lower rear is cake. that one bolt and then you just pull them out to the OP. this is what you'll have left when you're done :lol: http://i237.photobucket.com/albums/f...s/100_0641.jpg http://i237.photobucket.com/albums/f...s/100_0647.jpg |
Originally Posted by 1995blacktattop
(Post 11282803)
LOL that looks familliar...I think thats a writeup i posted when i was redoing my upholstery. i see i goofed a bit on the rear seats, i meant one bolt per side for the upper part of the back seat. |
(Post 11282517)
what holds the shift knob on a auto? |
Originally Posted by StrobinSS
(Post 11283246)
At the front of the knob there should be what looks like a staple. Take a flathead screwdriver and pull it straight out, that's all that holds the knob on. Joel did you see i repainted my valve covers? I started a new thread. They are no longer cast iron. They are now black :) |
thank you all for all the help. |
oops, someone already answered about the auto shift knob. haha |
© 2024 MH Sub I, LLC dba Internet Brands
